Smoking Valve Cover gasket? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-15-2008, 03:19 PM   #1 (permalink)
Andrew Liu's Avatar
View Andrew Liu's Photo Gallery
I recently replaced the valve cover gasket, and now whenever the engine is running at normal operating temp, smoke starts coming out of the engine, from the gasket.
It smells like burning rubber, but there are no leaks or anything, it works perfectly.
It smokes a lot after it warms up from a cold start, and it smokes much less after everything warms up.
Is this normal? Or is there something I should do to get rid of the smoke?
Andrew Liu is offline   Reply With Quote
Old 08-15-2008, 06:10 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
It is not normal but darned if I can think why it would be doing this. Was this a stock gasket or did you fabricate from gasket matterial? Did you use any cleaners, paint or solvents? Does it look like the gasket is smoking or smoke is coming from inside the engine past the gasket?
Kep
Old 08-15-2008, 07:55 PM   #3 (permalink)
Andrew Liu's Avatar
it just sorta floats up from around the gasket area. doesn't fully materialize into smoke until about 6 in. above the valve cover.
I did use a rag wetted with simple green to clean the gasket area, but that should've evaporated before i even installed the gasket the next day.
This is a Beck-Arnley gasket.
there is no noticable engine problems, or noise/performance problems. It just looks and smells terrible. no leaks, nothing.
Old 08-15-2008, 09:37 PM   #4 (permalink)
View mtmx46's Photo Gallery
3rd Generation
I had the same problem. Your valve cover gasket needs to be torqued properly. If that fails then you need high temp gasket sealant. It's not as bad as it looks. You need a 30mm? socket and go in sequence. It's probably spilling from the back end and once the engine heats up... out comes the smoke!
Matt
StillTikin96, 1996 Toyota Camry Four Door, 2nd owner
5SFE Automatic - 348,784 km
Studded Winter Nexens on 14" steel rims
Running Castrol 5w20 for now
mtmx46 is offline   Reply With Quote
Old 08-16-2008, 06:40 PM   #5 (permalink)
Andrew Liu's Avatar
I just did that and it seemed to fix the smoking.
However, there is still the smell, but thats probably just the excess already spilled.
