Originally Posted by kev12mich
The back left window in my car will not go up. The regulator and motor on it was busted originally, but I replace both. When I tested the window, it would roll down, but not up. I figured the switch was broken. I ordered a new switch, and it still will not go up. I'm thinking perhaps there is a problem coming from the master switch then? I'm not quite sure how to fix this issue, any ideas?
I had a problem with chaffed wires in the rubber conduit between the door and the body.
This is a common problem on these cars. I had simmilar symptoms that sometimes the window would work, and other times it would not. Same thing with the door lock.
This can be fixed by removing the door panel, and the trim panel in the car.
Pull back the conduit and check for chaffed wires. If they are chaffed, cut out the bad section, and solder in a longer wire, then cover with heat shirk tube.
The only other thing I can think of is to lube the window run with silicone spray. The rubber becomes hard as it ages.
