Well i removed the fuel injectors. To anyone doing this. On the v6 model. remove the egr first, then the 6 bolts for the intake penum. Then the thing with all the hoses above the front fuel injectors. Also take out the gas cap.
Now this is the trickey step, if i knew this it would have saved me soo much time and hassle.
Between the rear fuel rail and the fuel filter, remove the bolt that is attached to a metal thing, attached to the fuel line. Then remove the fuel line return on the front rail on the right side. Now remove the fuel line on the rear rail on the left side. Now unscrew the 4 bolts holding down the rails. Remove the front rail and take out the fuel injectors. Then left the rear rail up and removes its injectors.
I swear if i knew this, it would have saved me soo much time, rebending the fuel lines into the proper position.
The first time i tried starting my car it failed since the fuel lines had air in them. The 2nd time it started and idk maybe its all in my head but it sounded very smooth. Hopefully cleaning the fuel injectors will fix my problem.
1995 Camry V6 LE - Sold
1998 Camry LE
1992 SC300 5SPD
1992 SC400
