Rear Thump one more time! 95 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2008, 10:08 AM   #1 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
I have taken pics of my rear suspension. I suspect the thump is coming from the Strut rod, being bushings are shot, just because the thump I hera and feel is like coming from the body of the car...like in the trunk, underside of the body.....
Help me out, I have read replacing the sway bar bushings did the trick, but looking at the parts list, there is nothing called sway bars...
Please point out [/IMG]the obvious to me...
Thanks.
04 SC430 05 RX330
96 Camry LE T-boned Oct. 09 RIP
mandyfig is offline   Reply With Quote
Old 08-16-2008, 10:10 AM   #2 (permalink)
mandyfig's Avatar
[/IMG]
I am trying to post a link....
04 SC430 05 RX330
Old 08-16-2008, 10:10 AM   #3 (permalink)
mandyfig's Avatar
http://i184.photobucket.com/albums/x...d95CamryLE.jpg
04 SC430 05 RX330
Old 08-16-2008, 10:11 AM   #4 (permalink)
mandyfig's Avatar
http://i184.photobucket.com/albums/x...5/IMG_5787.jpg
suspension pic
04 SC430 05 RX330
Old 08-16-2008, 10:12 AM   #5 (permalink)
mandyfig's Avatar
SWAY BAR Bushing?
http://i184.photobucket.com/albums/x...5/IMG_5782.jpg
04 SC430 05 RX330
Old 08-16-2008, 10:15 AM   #6 (permalink)
mandyfig's Avatar
Another look..
http://i184.photobucket.com/albums/x...5/IMG_5785.jpg
04 SC430 05 RX330
Old 08-16-2008, 10:17 AM   #7 (permalink)
mandyfig's Avatar
Rear Suspension
http://i184.photobucket.com/albums/x...5/IMG_5781.jpg
04 SC430 05 RX330
Old 08-16-2008, 10:52 AM   #8 (permalink)
The Connoisseur
CharmCityES's Avatar
bad strut mounts....they tend to make a bad knocking noise
id just replace the whole shebang....struts, mounts and the bushings
The "Executive Sedan"
Old 08-16-2008, 11:33 AM   #9 (permalink)
mandyfig's Avatar
Even if only the bushings are worn out? Thanks.
04 SC430 05 RX330
Old 08-18-2008, 10:49 AM   #10 (permalink)
mandyfig's Avatar
When I go to Autozone to get the bushings, which ones will I specify?
04 SC430 05 RX330
Old 08-18-2008, 01:18 PM   #11 (permalink)
Unco's Avatar
View Unco's Photo Gallery
jack the back of the car up so the rear wheels are hanging down. grab the each tyre at 3 and 9 o'clock and push/pull to see if there's excessive play. check the lateral rod bushings in particular. that was the problem with my last gen3.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 08-18-2008, 01:21 PM   #12 (permalink)
View 1996camry's Photo Gallery
I have the same problem....Every time my car goes over a hold on the road, I heard a noise on the rear. the way you test if your rear shock was the problem... hold your hand and press down and let it go. You should see bounce 1-3 then stop. if you see more than 3, your rear shock needs replace.
I don't think your rear shock was the problem... your bushings are the problem...
the bushings are the black rubber on the rear under the car connect (clamp) with the long swap bar across on both your wheels.
I got both bushings on my 96 toyota camry Le 4 cylinder for 30 bucks from the dealer.... Call dealer and check the price...I think your car should be cheaper than mine because your car is an older model. Replace each bushing at a time and look at the old versus the new as far the installation orientation.
After I replaced rear bushings, the noise went away. Go for the easy first before spend $ on rear shocks that weren't the problem.
1996camry is offline   Reply With Quote
Old 08-18-2008, 01:21 PM   #13 (permalink)
Unco's Avatar
Originally Posted by mandyfig View Post
that's your sway bar bush right at the top of the pic.
Old 08-18-2008, 01:29 PM   #14 (permalink)
mandyfig's Avatar
Thanks a lot guys. Replacement is as easy as unbolt, dis-mount and mount new bushings? Obviously while the car is jacked up.
However, I will try the 3 and 9 o'clock check. Maybe I can actually hear the thump. Mike Gerber recommended this....
Thanks again!
04 SC430 05 RX330
Old 08-18-2008, 02:17 PM   #15 (permalink)
mandyfig's Avatar
One more ? When I replace these bushings, I do not need to re-align right?
04 SC430 05 RX330
