Removing Windows Please Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-17-2008, 07:35 AM   #1 (permalink)
View commie92's Photo Gallery
I am having alot of trouble finding how to remove the windows from passenger door and rear right door. This includes the little window on the rear door as well. Someone please help. What to unscrew and do i pull the up and out?
commie92 is offline   Reply With Quote
Old 08-17-2008, 08:43 AM   #2 (permalink)
View djb2's Photo Gallery
What specific problem are you having?
Do you have the inner door panel off? The two screws holding the window to the regulator? After that it's just figuring the angle to tilt the window out slightly and which edge to pull up first.
djb2 is offline   Reply With Quote
Old 08-18-2008, 08:58 PM   #3 (permalink)
i got the trim off. them i see a vertical metal bar do i unscrew the three nuts that hold that?
Old 08-20-2008, 09:07 PM   #4 (permalink)
i still cant get them out.
i unscrewed everything and its not coming out.
please someone help? thanks a bunch
Old 08-20-2008, 10:59 PM   #5 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
I'm going from memory so I may miss something, but I believe you do the following:
for rear doors:
  • remove inner panel.
  • roll window down, and unbolt the two bolts holding the glass in place
  • carefully pull back the weather stripping from the top back corner
  • remove top screw and bolts holding the metal brace between the window and back quarter window
  • carefully remove glass
  • slowly work the quarterglass out [it should basically pull out but needs coaxing for it to come
for front doors:
  • roll window down, but not all the way down
  • unbolt the two bolts holding the glass in place
  • roll the window the rest of the way down
  • carefully tilt the glass forward bring the back end up
  • take your time and work the glass up until it comes out [it'll come out on the outside of the door frame]
be careful with putting it back in, or it won't work properly when you roll it up. Trick is to get it into place, bolt it in snuggly. Then roll it up until it's approx 3" from the top. Then tilt it all the way into the back of the frame and then tightened up the bolts. If you don't do this, when you roll it up, it won't fit in properly and end up on the outside of the weatherstripping.
Hope this helps. Good luck!
cykaaro is offline   Reply With Quote
