ac compressor oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-17-2008, 03:23 PM   #1 (permalink)
View SamMan23's Photo Gallery
ac compressor oil
Does anybody know how much pag oil to put into the ac compressor? or how much r-134 to put? This is going into a 93 es300.
Sam
ToyotaSamChen@hotmail.com
SamMan23 is offline   Reply With Quote
Old 08-18-2008, 10:11 AM   #2 (permalink)
View jaybur_racing's Photo Gallery
take it to a shop. It might look more expensive at first, but if you put too much in of either, you can cause the compressor some serious damage.
besides, if you need to add refrigerant, there must be a leak somewhere in the system, best to get it professionally checked out.
jaybur_racing is offline   Reply With Quote
Old 08-18-2008, 04:24 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
The NAPA specs show that it came with R-12. Are you certain that it has been converted. If it has, are you certain that the problem that you are repairing might not have occured because of a less-than-thorough conversion job (that may still need to be fixed).
NAPA capacity sheet:
http://www.napabeltshose.com/downloa...s&view=napa_hc
Kep
