96 Camry Cat Converter Question P0420 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-18-2008, 10:58 PM   #1 (permalink)
View Avantgarde's Photo Gallery
Hi,
I have my 96 Camry(2.2) with 177K miles on it.
At 173K(1 month ago), I decided to get my whole exhaust fixed(there were three big holes. One on the flex pipe, one on the cat converter and one another on the muffler(Here in Ohio there is a lot of rust). I had my repair guy replace the flex pipe and muffler with aftermarket ones, and remove the cat converter and replace a direct pipe to there. After this replacement I drove the car for more than 25 days and 3k miles, and didnt get any check engine light.
A few days ago check engine light came with the error code P0420. I have read the other topics on the forum. Here my question is,
I'm very happy with the performance of my car w/o cat converter and I don't care the smell. Is there a way of hacking of this light only for this error(because I want the light to come if there is any other problem)?
http://www.oqcgp.com/upgrades/o2spoof/o2spoof.php
I think the method given on the link decreases the voltage of second O2 sensor, so that ECU thinks that O2 amount after cat is ok. Is that applicable at 96 Camry?
If the only way of getting rid of this code is installing a new cat conveter, what's your suggestion going to be? What is the best practice brand? I don't want to spent a lot of money on a new one, either get fooled by a broken one at junk yards..
Thanks for your replies.
PS: Another option seems to remove the fuse for ECU for a couple seconds, however this is something temporary..
Avantgarde is offline   Reply With Quote
Old 08-19-2008, 02:32 AM   #2 (permalink)
Starr of Chaos
lordstarwind's Avatar
View lordstarwind's Photo Gallery
best way would be to get an O2 eliminator or spacer and put the O2 sensor in the exhaust pipe where it belongs , the spacer moves it out of the exhaust stream and still lets it send the signals its suppost to while an eliminator would fool the computer into believing the signals from the eliminator are the signals from the O2 sensor and tells it that the air/fuel ratio is correct...
spacer is cheaper
eliminator is good, but it might be hard to find one that works with toyota ECU's
-LSW
lordstarwind is offline   Reply With Quote
Old 08-25-2008, 01:04 AM   #3 (permalink)
Thanks a lot for the reply. I'll search for a spacer too.
However I'm wondering if I can make the modification at a 96 camry the way on the link given at my first post..
Old 09-04-2008, 08:19 AM   #4 (permalink)
4wd TN user
View Rolla86's Photo Gallery
Nop, it will not work because your O2 sensor has only 2 wires, not four.
1998 Rolla CE, 5 speed, TSW rims ==>> SOLD
1996 Camry LE, 5 speed 5SFE ==>> SOLD
1993 Pick-Up 4wd SR5, 3VZE, 5 speed, 32x11.50 BFs on 99 4Runner wheels ==>> SOLD
1996 T100, 4wd, 5VZFE, 5spd, 15" Alcoas, 260k in the clock and going for more
Rolla86 is offline   Reply With Quote
Old 09-21-2008, 01:40 PM   #5 (permalink)
Well, before I got action and did something to turn off the light, it went off itself yesterday. No check engine light anymore. I didn't do anything. Didn't touch fuse or ECU.
The thing is that I still don't have a cat converter. Is this normal?
