Where is my fill plug? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-19-2008, 02:40 AM   #1 (permalink)
View dleccord's Photo Gallery
I have a 1994 Toyota Camry 2.2L, and I don't know where the fill plug is at on the engine.
Do I pour the ATF into the tranny dipstick?
dleccord is offline   Reply With Quote
Old 08-19-2008, 02:53 AM   #2 (permalink)
Unco's Avatar
View Unco's Photo Gallery
are you looking for the fill plug for the engine or the transmission? manual or auto?
engines have filler caps.
automatic transmissions have filler tubes.
manual transmissions have filler plugs.
so which one is it you're after?
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 08-19-2008, 03:02 AM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Don't forget there's a differential too.
2007 Camry 2.4L 5M
Old 08-19-2008, 03:04 AM   #4 (permalink)
The womaneater!!!!!!!!!!!
samarai912's Avatar
View samarai912's Photo Gallery
yeah you gotta get a transmission funnel and fill it through your dipstick tube. throw a couple quarts in then start the the motor, while its on check it the dip stick and fill fill till its full.
GF:"samarai I want to marry you." Me:"Uhhhh..I made a mistake.I only love my car"
Camry gen4 1mz turbocharged @ ? bar(updated)
.http://www.cardomain.com/ride/3029563
samarai912 is offline   Reply With Quote
Old 08-19-2008, 03:49 AM   #5 (permalink)
I said ATF in my post.
But isnt it in a different compartment or do they both sharing the same tranny fluid.
Yeah but then how do you know it's full? All it says is cold and hot.
Old 08-19-2008, 04:00 AM   #6 (permalink)
Unco's Avatar
it's not "on your engine".
since you're looking for the "filler plug" on the engine. i wouldn't put it past you that you're trying to put ATF in your engine.
don't assume so much buddy. manual transmissions can also be filled with ATF. we're just trying to help here.
if the engine is cold, fill it up to the cold level on the dipstick. then check it again when the engine is hot. preferrably the level should be checked with the engine hot after taking the car for a drive.
place the gear selector in Park and pull the dipstick out. clean it up and quickly put it back in all the way and pull it back out again. it should now be level with the "hot" mark on the dipstick. if it's not, add some until you get it to the right level.
Old 08-19-2008, 04:46 AM   #7 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
Ok, let's clear one thing up. The "Hot" and "Cold" marks on the transmission dipstick refer to the temperature of the transmission fluid, not the engine coolant temperature.
When refilling your transmission after the old fluid has been draind, fill the transmission to the top "Cold" mark. Typically, it's 2.5qrts of ATF for a drain and refill. I've done this dozens of times since I've had my Camry.
When you check the trans fluid, the level will be different depending on when you check it. If you check it right after you start the engine 1st thing in the morning, the level should be between the the two "Cold" marks. If you check after you drive a few miles it should be between the two "Hot" marks.
Whatever the temperature of the fluid (hot or clod), as long as the fluid level is between the corresponding temperature range marks on the dipstick, your fine. The amount of fluid doesn't have to be exactly spot on, though it is preferable. As long as it's not running low, don't worry.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 08-19-2008, 08:09 AM   #8 (permalink)
On a 94 with a 2.2 auto, the differential fluid is separate.
2007 Camry 2.4L 5M
Old 08-19-2008, 09:14 AM   #9 (permalink)
View JustinC25's Photo Gallery
if you wanna be exact there is a fill plug check at the back of the transaxle. kind of a bolt that runs along the ribs of the transaxle. theres only one so its not hard to find.
jack the car up on stands and unbolt the filler plug check. then fill till it is coming out of the filler plug check and levels off. then plug it and your done. [/QUOTE]
The plug on the rear is for the differential, and is housed in a seperate compartment of the transmission, and has nothing to do with the fluid level in the body of the trans, only the diff.
This is why there are 2 drain plugs.
You should change the diff fluid at the same time as the trans.
When you go to do this make sure that you can remove the fill plug FIRST!
Many people over tighten them, or round off the heads. When is happens you either need to remove it with a turbo socket, or an air chisel to loosen it.
As far as the question about checking the fluid on the dip stick, there are 2 notches above the cold, and 2 notches above the hot. You want it to be between the 2 notches for the condition of the transmission. "Hot" is after 3 or more miles of driving. When first filling the trans, it is ok to go a little over when "cold". When I worked for the dealer we used to put it between the cold and hot marks, and road test it. When we got back it was perfect.
I have the same setup in my Camry, It never takes more than 2 qts. Usually it is like 1- 1/2 to 1-3/4 qts. in the trans body. If you over fill it, it will shift strange.
JustinC25 is offline   Reply With Quote
Old 08-19-2008, 11:44 AM   #10 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
VERY good information not to forget. i cant believe the number of people that run into this problem on differentials, manual transmissions (speaking of which the manual trans on my camaro uses ATF as an example for earlier in the thread) and transfer cases.
Old 08-19-2008, 03:40 PM   #11 (permalink)
Thanks and sorry. I thought you use manual gear oil for manual trannies and ATF for autos.
So if Im just doing my tranny fluid change alone, do I have to remove any fill plug to prevent it from getting stuck if I remove it next time, or is that just goes for the differential.
One more thing, my fill plug is basically where the dipstick is, correct?
Thanks
Old 08-19-2008, 05:03 PM   #12 (permalink)
uibalnme's Avatar
You don't have to remove that plug, because that's for the differential. Yes, the diff., and the trans are seperated, and don't share fluid. Each is drained and filled from different locations. Just remove the transmission drain plug, drain the fluid, reinstall the drain plug, remove the transmission fluid dipstick, pour new trans fluid into the trans dipstick tube, start engine, and check trans fluid level with engine running. That's it.
Old 08-19-2008, 05:11 PM   #13 (permalink)
Wow, perfect answer. Thanks man.
Just out of curiosity, where is the drain plug for the differential and does it use the same ATF for my automatic tranny?
Old 08-19-2008, 05:35 PM   #14 (permalink)
uibalnme's Avatar
The diff. drain plug is on the bottom of that ribbed area of the transaxle that was discussed earlier in this thread. The fill plug for the diff. is the one on the back of that ribbed area closer to the top, also discussed earlier.
Here's an online repair manual...
http://www.**********s.com/camry/ax1.pdf
Look at page 13/second picture from the top on the left. The little "dot" bottom center of that picture is the diff. drain bolt.
Both the trans, and differential use ATF. They just have seperate supplies of ATF. Like I said before, they don't share the same supply of ATF. Each must be drained, and refilled seperately. Though the diff. fluid(ATF) only needs to changed every 12k - 15k miles. Personally I change the trans fluid, and diff. fluid every 3rd oil change to make things easier to remember.
Old 10-02-2008, 09:40 PM   #15 (permalink)
View outapsyt's Photo Gallery
i thought the diff and a tranny were separate compartments too.
but i sprung a leak on my diff from the gasket and
i couldn't find a leak anywhere else on the tranny.
but the dip stick comes up in the cold level even after a 40 mile drive.
outapsyt is offline   Reply With Quote
