My wife came home 2 days ago, and the front drivers side window was stuck.
Midway down.
I searched the forums and internet, and found a few articles.
The one (very good) DIY switch article.
And the many threads about the wires between the door and the body.
I took apart the switch.
WARNING: Do this on a clean flat table with good light.
Keep the finger switches UP (like it is in the car) when you pull the cover, so the springs and "butterfly"/"toggle"/"seesaw" things don't go all over the place.
I was lucky, and with the DIY article, didn't screw this up.
NOTE: The switch (internal workings) of the Drivers Side Front Window is significantly different than the others (for those of you who this one window out)
I ended up doing the clean and file at the DIY article. I filed the plastic finger switch down a little.
I put it back to together.
It worked for a few seconds. I got the window up.
THEN NOTHING?
Huh?
I took the switch back apart and there was one spring got off its perch, and shorted something.
CRAP. I was almost done. Learn from my mistake and be careful putting the switch back together. Actually, you should put it together, take it apart, just to take sure your "gentle touch" is gentle enough not to move the springs or butterfly/toggle/seesaw things.
Well, NO POWER to anything in the door.
I check all the fuses by the turn signal (the little door that opens up with the normal fuses behind it). All work. (using a test light).
I check the front fuses. No issues.
Well, I've learnt one thing with this camry. When you think you've found all the fuses, you haven't.
I google, and find out there is a 30 amp fuse above and to the right of the "normal" fuses near the turn signal (drivers left knee area).
I figure out I have to remove the main bottom panel below the steering wheel. I'm talking about the 7 inch by 24 inch main panel, covering up most of the stuff below the steering wheel. 4 10mm nut-screws and a small screw near the "normal" fuse box (by the drivers left knee area).
There is a 30 amp fuse that you can get now. Sure enough, it was blown.
So (at least in this 1993 Camry) this 30 amp fuse is the big fuse controlling the main power out to that switch.
I'm off to the part store for a big 30 amp fuse.
Hopefully, when I get it all wired back up, all windows will work.
I'm sure all this information is available somewhere in these forums, but I thought I'd outline what I experienced.
I think I'm gonna order a new switch, since we are planning on keeping the car for a while.
All the contact points in this switch are very "burnt". It just seems like a device built to wear out.
I'll try to report back the final outcome.
THANKS for all the previous posts. If you're reading this ( or other posts ) you should always pay-back and tell your experience. Sometimes it takes a few perspectives to help others (as others have helped you, or you wouldn't be here at all, right??).
I'm not sure of the exact/correct name, but this
JCASE HIGH AMP FUSE, PINK 30 AMP
when I googled it, shows the type/shape of the 30 amp fuse I'm talking about. As in, its not the blade type fuses that you usually see in late 80's,90's,2000's cars.
