A/C Linked to defroster on 96 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2008, 08:31 AM   #1 (permalink)
View bors's Photo Gallery
I just picked up a 96 Camry and noticed that the front windshield defroster does not work well unless you switch on the A/C. So my question is are they linked together or must you turn on the A/C separately. Everything appears to be working.
bors is offline   Reply With Quote
Old 08-20-2008, 08:41 AM   #2 (permalink)
View gorckat's Photo Gallery
I don't think manufacturers started making the A/C turn on automatically until recently.
I've had to turn on the A/C, set the air to 'outside' and turn up the heat to make defrost work correctly on all the cars I've owned.
gorckat is offline   Reply With Quote
Old 08-20-2008, 09:56 AM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $348853
View BMR's Photo Gallery
If you live in a humid climate, it's normal for the front defroster to not work very well without the AC turned on. When the air goes thru the AC's evaporator (the radiator that cools the air), some humidity condenses on it. Then it goes thru the heater core to warm it back up. The result is that you get drier air blowing on your windshield which does a better job of defogging it. Here in desert-dry CO, it's usually not necessary to do that. Which is why I'd rather not have the AC come on automatically when running the defroster.
BMR is online now   Reply With Quote
Old 08-20-2008, 03:37 PM   #4 (permalink)
Gameroom cash: $303255
I believe Toyota integrated the A/C with the defroster setting on the generation 4 Camry; that is, beginning with the 1997 model year. Before that you have to manually turn on the A/C when in defrost mode.
Mike
Mike Gerber is online now   Reply With Quote
Old 08-21-2008, 12:33 AM   #5 (permalink)
View 97vulcan's Photo Gallery
can anyone confirm if the above is true.
Adam
Mine:
1992 Camry LE 5sfe 128,000 miles
1998 Ford Contour SVT 148,000 miles(SOLD)
Wifes:
1994 Camry LE 5sfe 224,000 miles
97vulcan is offline   Reply With Quote
Old 08-21-2008, 09:54 AM   #6 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
bors - I just thought of something. When you run your defroster and the windshield fogs up, can you smell antifreeze? If you can, you probably have a heater core leak.
Old 08-21-2008, 11:35 AM   #7 (permalink)
Woo Hoo!!
sbushnak's Avatar
Gameroom cash: $173010
View sbushnak's Photo Gallery
Mike
Adam
Yes it's true.
1997 Toyota Camry LE I4
@ 193,000 miles
sbushnak is offline   Reply With Quote
Old 08-21-2008, 12:20 PM   #8 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
i ahve a 1996 camry and my AC compressor turns on automatically when the defroster is turned on? though the AC dash light does not night, but i know for sure everything is running.
Old 08-21-2008, 12:24 PM   #9 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
^ It shouldn't. I have both a V6 and I4 1996 camry, and neither do it.
Mike is right. He knows what he is talking about.
5 Lug Corolla WHAT?
Old 08-21-2008, 08:16 PM   #10 (permalink)
Mike
Thanks Mike, I suspected that might be the case. The defroster works OK it's just very slow unless I turn on the A/C, reminds me of my old camaro LOL. I just wanted to make sure before I go tearing the dash apart chasing after ghosts. I will let my daughter know that what she has to do in the mornings is turn on the A/C with the defroster.
_____________________
1996 Camry
2001 Sienna
2002 Tundra 4x4
2007 Yaris
