screeching start? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2008, 10:17 PM   #1 (permalink)
xxswat718xx's Avatar
View xxswat718xx's Photo Gallery
4th Generation screeching start?
Hey guys, tried searching this up but didn't come across anyone with my specific problem. When I start my camry, it'll idle really low. Almost to the point where it's going to turn off. Then if I give it some gas, there's this LOUD screech that won't let up as long as I have my foot on the gas. Eventually it goes away, but it still bugs me.
Same with my a/c. When I turn it on, it'll squeel for a few seconds. Or if I'm stopped at a light with the a/c on, when I take off, it's just screeching till I turn it off. Once I turn it on again, it ok... till the next stop :/
Btw, my Camry's an I4 with 164xxx miles on it. Any info would be really appreciated. Thanks guys.
97 Toyota Camry LE (4cyl), TRD muffler, TRD RSB, TRD STB, Injen Short Ram Intake, Clear Corners, Debadged
xxswat718xx is offline   Reply With Quote
Old 08-21-2008, 11:27 PM   #2 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
have you check the belts?
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 08-21-2008, 11:48 PM   #3 (permalink)
All of them? Or is there one I should check specifically? No, I haven't checked any. What should I look for?
Old 08-22-2008, 12:04 AM   #4 (permalink)
SkinnyConHeo's Avatar
View SkinnyConHeo's Photo Gallery
Originally Posted by xxswat718xx View Post
Same with my a/c. When I turn it on, it'll squeel for a few seconds. Or if I'm stopped at a light with the a/c on..
My A/C does the same thing when I turn it on. I have no idea what causes all the squeeling. But that shit sure is embarassing.
Problems I've fixed with the help of this forum:
The brakes squeak annoyingly.
Problems I still need help with:
Driver lock button locks all doors BUT driver's door.
Driver electric seat buttons and gas door switch don't work.
SkinnyConHeo is offline   Reply With Quote
Old 08-22-2008, 04:26 AM   #5 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
loose belts often cause this, thats why the first reply mentioned them - simple tensioning is often an easy and proper fix, but sometimes you might have to make some replacements
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 08-22-2008, 11:18 AM   #6 (permalink)
View picabu's Photo Gallery
4th Generation
I have the exact same problem. Replace the belt (the bigger one that connect to the alternator, not the powe stearing one) and no more screetching at all. Try adjusting the belt by tightening that tension adjustment screw on the alternator and see if it helps...if not, you may need to replace it.
Andy Nguyen
2007 Camry CE - lightly modded
1998 Camry LE - Bone Stock
2005 Dodge Grand Caravan SXT
picabu is offline   Reply With Quote
Old 08-22-2008, 01:42 PM   #7 (permalink)
Black95Cam's Avatar
all... loose, crack, damages, etc..
Old 08-22-2008, 01:54 PM   #8 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $348853
View BMR's Photo Gallery
There are two belts. The serpentine belt runs the AC compressor. It's the most visible one. It's adjusted by moving the alternator via a jackscrew. There are a couple of mounting bolts that need to be loosened first, tho.
The second belt runs only the power steering pump, which is driven off the crankshaft pulley. To adjust its tension, you need to remove the passenger-side front wheel and then remove a plastic access cover in the wheel well to reach the adjusting bolt. There are two bolts holding the pump bracket, one pivot bolt and one that rides in a curved slot (no jackscrew). Loosen those two and with a pry bar pivot the pump to apply more belt tension. And, of course, retighten the screws when you're done.
That's how my two Toyotas are, anyways.
BMR is online now   Reply With Quote
