a/c vacuum hose undone or broken, cant find where - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-22-2008, 09:50 AM   #1 (permalink)
My leather so soft
Gameroom cash: $104610
View the94camryman's Photo Gallery
air is only coming from my outer two vents and my defrosters, so im pretty sure there is a vacuum hose undone or broken or something, but i cant find where. anyone had this problem and fixed it and could help me.
the94camryman is offline   Reply With Quote
Old 08-22-2008, 10:29 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Xtremeskier96 has done some of this as have others. Two threads are:
Center Vents...no air!
Does ANYONE know where I can find these?!
Others could be searched for.
Kep
Old 08-23-2008, 11:50 AM   #3 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
I dont think our gen camrys use vacuum hoses to control the damper selection. I KNOW the Gen 3 doesnt, and Im 99% sure the Gen 4 doesnt either.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 08-23-2008, 12:17 PM   #4 (permalink)
My leather so soft
i coulda sworn they did. the silver mesh looking thing at the back of the vents that you talked about in your thread, is that supposed to move? if so, does that control wether the air comes from the center vents or the defrosters? i have the cable and rotary switch type, not the push button, so i dont think there is a servomotor for the mode selecter. i know the blower motor dampers work though, so another cable might be undone somewhere else.
Old 08-23-2008, 04:44 PM   #5 (permalink)
No, that silver mesh does NOT move. The center vent dampers are underneath that and you cant reach them.
There is an inlet servomotor and an outlet servomotor. The inlet motor is the one on the blower that provides fresh air or recirculated air. If you have the rotary type and not push button, you dont have an inlet servomotor, but you WILL have an outlet motor, which is the one that selects which vents the air blows out of.
It sounds to me like you have the same problem everyone else had, including myself, in that the plastic clip broke or came off of the push rod connecting the outlet motor to the dampers up in your dash.
Old 08-23-2008, 09:35 PM   #6 (permalink)
My leather so soft
where is the servomotor located at
Old 08-24-2008, 08:44 AM   #7 (permalink)
The oultlet servomotor is located to the right and up of your right foot while driving. You'll need a flashlight to see up under there.
Old 08-24-2008, 11:03 AM   #8 (permalink)
My leather so soft
ill check that out. does it involve removing the lower IP
Old 08-24-2008, 02:39 PM   #9 (permalink)
My leather so soft
i was out driving today and when the air is on high a small amount of air comes from the center vents. so it has to be the door is not how its supposed to be. ima look into it later on
Old 08-24-2008, 05:25 PM   #10 (permalink)
What is the lower IP?
You dont have to remove anything to see the servomotor.
Old 08-24-2008, 10:47 PM   #11 (permalink)
My leather so soft
by the IP i meant the dash. i was askin if you had to take off the piece under the steering column, but i guess not.
Old 08-25-2008, 03:08 PM   #12 (permalink)
My leather so soft
well i looked. the cable is hooked up to the motor, but not to the door. when i have enough time to fix it i will.
Old 08-29-2008, 08:36 PM   #13 (permalink)
My leather so soft
took a look at the a/c today. like i said the rod is hooked up to the motor, but not the damper fan. so i played with the fan. i can hear it moving, and air is redirecting from the defrosters. but air is still not coming from the center vents. so there must also be another problem
Old 08-29-2008, 09:25 PM   #14 (permalink)
What you are saying about the 'damper fan' I am not understanding. The fan and dampers are seperate. That rod you say is hooked to the motor should also be connected to the center vent dampers up top in the dash (only serviceable by removing the dashboard). What you are describing about the air coming out of the defrost vents and not the center is the EXACT problem I had, and I had to remove the entire dash to fix that rod to damper connection.
Good luck! Take your time and make sure you have plenty of it!
Old 08-29-2008, 09:53 PM   #15 (permalink)
My leather so soft
i apologize for that. by damper fan i meant the vent dampers. my family has always called it a damper fan and everyone knew what we was talking about.
appreciate all your help skier.
good luck to you on any problems you might encounter in the future.
