I am getting conflicting info on what the error codes mean. I thought code 34 was rear left sensor problem? and 36 meant right front or rear left?
Correct me if I am wrong. If its a sensor that is causing the problem, I will replace one, but I don't want to start replacing every ABS component on my car.
Also, because I started to mess with the ABS codes under the hood in the diagnostics port, my Airbag light has come on and is staying on with code 22. I want this to dissappear too.
Thanks,
Adam
Mine:
1992 Camry LE 5sfe 128,000 miles
1998 Ford Contour SVT 148,000 miles(SOLD)
Wifes:
1994 Camry LE 5sfe 224,000 miles
