How do I Use the Gen 3 Cruise and PWR? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2008, 02:56 AM   #1 (permalink)
View Sinned13's Photo Gallery
3rd Generation How do I Use the Gen 3 Cruise and PWR?
I know were the cruise is at and what it does but im a bit confuse on what some of the functions listed on it does. Can someone explain to me what moving down/up and pulling back the cruise stick does?
and also what the PWR button near the automatic stick is for?
when and when not to use them.
thanks.
Sinned13 is offline   Reply With Quote
Old 08-23-2008, 03:25 AM   #2 (permalink)
Noob
View gladis's Photo Gallery
OK, this is in my experience (and how I use my cruise control)
Press the button to turn it on, then when you're at the speed you desire, push the stick down to set the speed. While cruising, pushing the stick up will increase the speed, pulling it back cancels the cruise control.
On some cruise controls, pushing the brake (which turns it off), then pressing resume is supposed to resume the speed, while pressing reset is supposed to set it at the current speed (I'm not sure whether the Camry has that functionality)
PWR basically delays upshifts to nearer the redline than usual. This is practically useless for the 5SFE since the engine is not rev happy at all.
1996 Toyota Camry LE 2.2 - 139xxx 162xxx
2000 Toyota Sienna XLE 3.0 - 82xxx 104xxx
08/08 08/11
gladis is offline   Reply With Quote
Old 08-23-2008, 04:00 AM   #3 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
^ Ditto
When you press the PWR button near the gear selector, the shift points become more aggressive. It's supposed to give you more power (as the name implies) but it comes at the expense of fuel economy. I haven't driven an I4 gen 3 Camry but the V6 has more than enough power so there really isn't a need for the PWR button.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 08-23-2008, 06:46 AM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
all the PWR does is hold the shift till near redline and make down shifts more sensitive to throttle position. this allows the engine to take advantage of the higher rpm where it makes more of its power but will eat gas. its good for passing and merging, things like that,
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
