Yes, the O/D off light is at the bottom under the green "PWR" light in your instrument cluster where you see what gear you're in. The light went out on my mom's gen 3.5 so I swapped out the bulb with another one that was unused. Changing the bulb involves taking apart your dash and taking out the instrument cluster. Isn't too hard once you figure out where all the clips and screws are.
As long as O/D is working as it should be mechanically, it's not a problem. I just changed it because I was also changing the "D" indicator light which burned out. Naturally that is the first one to go since it's on most of the time.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
