It's the intake plenum that some folks remove. But it's not necessary. With the right extensions and a U-joint, the rear plugs can be replaced without removing the plenum. It's been a while, but I think it goes: plug socket, 6" extension, U-joint, 6" extension, and then a ratchet wrench. It's still a pain because it's so cramped back there, but it can be done.
As for plug brands, a lot of folks recommend Densos. I've used Bosch with no probs.
