Putting overdrive cover back on? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2008, 04:18 AM   #1 (permalink)
Tech In Training
View Gun5's Photo Gallery
tranny = A140E.... the O/D cover isn't wanting to fit back on correctly i'v spun the gears over a million times to see if they needed to be lined up a certain way just can't get it
Ryan
2000 Camaro Z28 - Full Bolt ons, Heads/Cam
1994 Firebird Formula - Full Bolt ons, Heads/Cam *Parted Out*
Coming Soon 1995 Camry LE 165k
Gun5 is offline   Reply With Quote
Old 08-24-2008, 05:08 PM   #2 (permalink)
View toyomoho's Photo Gallery
Turn the gear clockwise to install into the case.
With the gear drive shaft up and case cover down the distance between the top of the overdrive gear face and case flange should be about 0.94 inch.
Old 08-25-2008, 12:06 AM   #3 (permalink)
Tech In Training
I Put the band in
then I put the gears in and goto put the o/d case over them and there is just too big of a gap.. or are you suppose to put the gears in with the o/d cover
Old 08-25-2008, 04:29 AM   #4 (permalink)
Put gears into cover when turning CW.
Check the distance shown between arrows in your photo, should be about 0.94 inch.
