Car sounds flat, exhaust problem?
Hey all,
6-8 months ago I seafoamed the car and saw some white smoke coming out of the front of the car, and I figured it was an exhaust leak. Not long after that I took it to the mechanic for an oil change, and a quick check of the car.
He said that there was an exhaust leak, and he "wrapped" it, and it should be fine.
I didn't notice any noise before, but over the past 3 months or so, the car is sounding louder than it should be, almost as though the engine was a bit flat. You can hear all the cylinders firing, and it sounds as though it's magnified. Is this an exhaust problem?
Oh, btw, it doesn't sound much out of the ordinary at idle, only under light throttle (1500-2500 rpm)
1996 Toyota Camry LE 2.2 - 139xxx 162xxx
2000 Toyota Sienna XLE 3.0 - 82xxx 104xxx
08/08 08/11
