radio troubles.... AGAIN! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2008, 10:54 PM   #1 (permalink)
youngflashycamr's Avatar
View youngflashycamr's Photo Gallery
ok so last time i made a post about my radio i was told that my best option was to get a new head unit...so i did...and i dropped it in and it worked beautifully...for about 5 minutes...then it went bck to boring old deadness...and everytime i pop the faceplate on and hope to god that itll work, it doesnt...my head unit is new and my speakers arent blown...what in the hell is my problem??
i like having had lulz.
also, shares his name with the first civic i got laid in.
AIM: imeffindash
Originally Posted by Venom_5 View Post
everyone IS entitled to an opinion .... yours is just wrong
youngflashycamr is offline   Reply With Quote
Old 08-26-2008, 11:11 PM   #2 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
Try unplugging the harness behind the deck first. Wait 1 min and plug it back in. If your deck turns back on but for about 5 mins before shutting off, I think its wiring problems. If you connected the orange or white w/orange strip (I think) wire from the harness to the dimmer, sometimes this happens. Once you remove it try again.
If none of that works, try checking the fuse. Or use a voltmeter and check the cars radio harness and see if you are getting a short somewhere.
GL
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
Old 08-27-2008, 11:01 AM   #3 (permalink)
my deck/head unit works fine
it just doesnt transmit sound to the speakers
also, bump
AIM: imeffindash
Old 08-27-2008, 08:18 PM   #4 (permalink)
View BigDog4All's Photo Gallery
Hope this helps...................
Constant 12V+.....Blue/Yellow
Switched 12V+.....Gray
Ground................Brown
Illumination..........Dark Green
Dimmer...............White/Green
Front speakers
Left Front (+).......Pink
Left Front (-).......Purple
Right Front (+).....Green
Right Front (-)......Blue
Rear Speakers
Left Rear (+).....Black
Left Rear (-).....Yellow
Right Rear (+)....Red
Right Rear (-)....White
BigDog4All is offline   Reply With Quote
Old 08-27-2008, 08:25 PM   #5 (permalink)
Noob Camry Owner
hoyota's Avatar
View hoyota's Photo Gallery
Front speakers
Rear Speakers
BLUE IS NOT CONSTANT POWER!!!! its the accessory wire. only use it if you have a power antenna or an amplifier. otherwise, it should not be connected to anything
hoyota is offline   Reply With Quote
Old 08-27-2008, 09:59 PM   #6 (permalink)
cruisn76's Avatar
Then I suggest you run a ohm meter to the speaker wires from the radio harness and on the speakers. Also check the polarity of the speaker connection.
