Prepping '93 from long-term disuse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2008, 06:41 PM   #1 (permalink)
View geeniusatwrok's Photo Gallery
3rd Generation Prepping '93 from long-term disuse
Evening...
I'm buying a '93 LE 4cyl automatic (US spec) that has been more or less unused for the past 4-5-6 years. It gets started 2-3 times a month to keep the battery up and the motor juices flowing, and driven at best once a year, maybe twice. The car only has 35,000 miles on it and has always been garaged in a dry environment, so there's no rust.
No, I am not telling where it lives
I would do the obvious things like flush and replace all fluids (oil, trans, brakes, cooling system etc), check all the belts and hoses, and replace the tires. I will be driving it x-country from So Calif to the Boston area. Any further suggestions appreciated. I think I should replace the timing belt because it's probably all dry and cracked from age, though I think that this engine is a non-interference design (I hope) but it would still suck to have it go twang in the middle of nowhere.
Then I would like to ask what might be some problems common to this year/engine/trans that I should be aware of. I did do a search on "common problem 93" that didn't really turn up much. I gather that the transmission might be a weak spot (and someday I will convert it to a manual but not any time soon).
I don't know much about these cars but I guess that'll be changing real soon.
Thanks!
geeniusatwrok is offline   Reply With Quote
Old 08-29-2008, 06:59 PM   #2 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
You've already mentioned alot of things to keep the car running. You should also change the spark plugs, cap & rotor, spark plug wires, O2 sensors, fuel filter, and power steering fluid.
As for "weak spots," having only 35K, the engine, and trans are brand new. If you keep the car well maintained, the engine and trans will last just about forever. The 4cyl(5sfe) does have a problem with leaking valve guide seals. However, that is only a common problem amoung high mileage cars with the 5sfe. The valve guides will not be any concern for you until you pass 100K.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 08-29-2008, 08:00 PM   #3 (permalink)
O-Dark-30
frenum49's Avatar
View frenum49's Photo Gallery
hmm
You mentioned the obvious. Now fill up the tank with premium fuel and add a bottle of injector detergent. Make sure the brake pads and rotors are okay. Don't forget to check the gear-box level as well as the trans fluid. You should be golden. Congrats on the find.
frenum49 is offline   Reply With Quote
Old 08-29-2008, 08:23 PM   #4 (permalink)
Thanks. This should be a 10-year car for me because I don't drive all that much, though New England winters might do 'er in before then. Wonder if it'd be worth getting that undercoating stuff...
"gear box"? you mean differential?
Old 08-29-2008, 08:43 PM   #5 (permalink)
O-Dark-30
frenum49's Avatar
On the auto trans in this case there is a drain and fill plug towards the back of the trans that contains the ring and pinion gears. I run 80/90 gear lube for this application.
Old 08-29-2008, 09:52 PM   #6 (permalink)
uibalnme's Avatar
That is for vehicles with the standard front engine-rear drive configuration, but not for front engine-front drive cars. At least, not for the Camry.
All service manuals for the 92-96 Camry state that the differential uses ATF just like in the transmission. 80/90 gear oil maybe too thick, and cause the transmission to work too hard to turn the gears reducing the gas mileage.
I've always used the same ATF in my differential as I do in the transmission, and I've never had any problems. My 96 Camry still runs flawless even after 135K.
Here is a link to an online repair manual for the gen3 Camry. Verifiy for yourself.
http://www.**********s.com/camry/
Old 08-29-2008, 10:50 PM   #7 (permalink)
O-Dark-30
frenum49's Avatar
Go ahead and put ATF in your gear box. I use 80-90.
Old 08-31-2008, 05:19 AM   #8 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
Premium on the 5S? There is no need for that. The 5S won't be able to advance its timing enough to ever take advantage of a higher octane gasoline.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 08-31-2008, 05:58 PM   #9 (permalink)
View frojoe's Photo Gallery
My 93' camry had sat in a garage for 6 years, never started or moved besides one trip across the road. I jump started it and drove it to the dealership. One quick tuneup (changed common fluids ect.) and I've driven it for almost two years since then with no maintenance besides oil changes every 3000 miles. It had 70,000 miles on it then, and has 85,000 now. I never even changes the tires. These cars seem to last forever.
frojoe is offline   Reply With Quote
