'98 4cyl factory tire pressure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-31-2008, 10:01 PM   #1 (permalink)
View lyrictenor1's Photo Gallery
I was going to check the tire pressures on my mom's '98 Camry, but found that the tire pressures printed on the door jamb sticker have worn away. Anyone know what the factory recommended settings are? I may adjust from those settings, but I'd like to know what their baseline is.
Thanks in advance..
lyrictenor1 is offline   Reply With Quote
Old 08-31-2008, 10:02 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
I don't know off the top of my head, but 30-32 PSI should be fine.
2007 Camry 2.4L 5M
Old 08-31-2008, 11:02 PM   #3 (permalink)
_
Gameroom cash: $221635
View uuuuu's Photo Gallery
My 3rd party tires have max pressure listed on the sidewall. Are the door jamb pressures only for stock tires?
uuuuu is offline   Reply With Quote
Old 08-31-2008, 11:08 PM   #4 (permalink)
just a nobody
The pressure rating on the sidewalls are maximum pressure that the tire can handle under certain loads. The car will be very bouncy if set at that pressure.
Tire pressure should also be in the owner's manual, if not the above posted range is a good start.
N.E.O.
Old 09-01-2008, 05:00 PM   #5 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
I agree. I'm usually in the 32-33 PSI range. My gen 5.5 recommends 29 PSI from the factory but I prefer to fill it just a little bit more.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 09-02-2008, 08:33 AM   #6 (permalink)
View lenjack's Photo Gallery
G0 33.
Any car problem can be fixed with a large enough hammer!
lenjack is offline   Reply With Quote
