Power Steering question... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-01-2008, 05:53 PM   #1 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Referring to the XLE in my sig
Yesterday my car started to overheat, and when it did, I was pulling into a parking lot turning right. When I was trying to turn right, the steering wheel would BARELY turn (almost hit a car). I got the car cooled down and refilled the coolant (after getting sprayed in the face by hot coolant). Power steering fluid has always been full, and still is.
So I cant figure out WHY I lost steering when my car started to overheat?! Anyone have any clues?
I looked at the ps resevoir when the engine was running, and it's full, so I removed the cap (car still running) and the fluid starts bubbling. Put the cap back on, and no bubbling. Pull it off again and bubbles again. What the heck?!
Can ANYONE shed some light on these?!
Thanks!
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 09-01-2008, 06:11 PM   #2 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
Have you noticed if the cooling fans are turning while the engine is running? I ask because I'm thinking that the 92/93 v6 uses a hydraulic cooling fan that is ran off the power steering pump. Perhaps the pump or something along the hydraulic path for the cooling fans are failing. I know it's a hydraulic fan, but without the shop manual in front of me, I can't 100% say that it's running off the ps pump (pretty sure, though).
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 09-01-2008, 06:20 PM   #3 (permalink)
just a nobody
The same pump is used, but it is a two chamber pump, front part for power steering and rear part for cooling fan. It does sound like the two problems are related; does your fan go to high speed when the engine gets hot or with A/C system on high?
Is the fluid actually bubbling or just sloshing around in the reservoir?
N.E.O.
Old 09-01-2008, 06:31 PM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $348853
View BMR's Photo Gallery
Yeah, the PS pump runs a hydraulic motor powered fan. Goofy setup, if you ask me. Like renmike asked, did you notice if your fan was running when it overheated? If the fan wasn't spinning, perhaps your PS pump is going bad, and that's why it overheated?
As for the bubbles you saw in the reservoir, I have no ideas. Usually in mine, if it's running, I see a little plume of fluid poking at the surface from the fluid returning.
BMR is online now   Reply With Quote
Old 09-01-2008, 06:39 PM   #5 (permalink)
The fan has always functioned properly. Runs fast when car is warm and runs fast when A/C is on. Runs slow at idle.
The PS Fluid was actually bubbling, not sloshing. And with the cap on, it was COMPLETELY still. No sloshing or bubbling.
Yes, the 92/93 V6 camrys had hydraulic fans, like mine. The LE in my sig is electric (would much rather have that).
Old 09-01-2008, 06:51 PM   #6 (permalink)
just a nobody
Was the fan functioning when you were having the problem?
N.E.O.
Old 09-01-2008, 06:52 PM   #7 (permalink)
Yes.
Old 09-01-2008, 07:05 PM   #8 (permalink)
Anyone ever changed their 92/93 V6 hydraulic fan out for the 95/96 V6 electric fans?
Old 09-02-2008, 03:22 AM   #9 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
so, does the car still overheat? and what was the cause of the overheating?
HaHa
Old 09-02-2008, 03:40 PM   #10 (permalink)
That's just it, I dont know WHAT caused it. I filled it back up and started the car with the filler cap off so that I could get all the air out of the system and topped it off. Closed the cap and it's been running fine yesterday and all day today. This happened a few weeks ago also. Never could find a leak anywhere.
Im thinking maybe thermostat not opening properly and causing coolant to spew out of the overflow?
Old 09-02-2008, 05:38 PM   #11 (permalink)
I forgot to mention...Ive always noticed with the XLE that it heats up to normal temp (going by temp guage, normally just under the halfway mark) REALLY fast. The LE in my sig warms up slowly, probably taking a good 5-10 minutes to reach normal operating temps (again, going by temp guage, just under halfway mark). The XLE takes just over a minute or so to get to that temp.
Could a bad thermostat cause this?
Old 09-03-2008, 12:30 AM   #12 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
In my experience, thermostats usually fail by opening too quickly, or worse, never fully closing, which would cause the opposite; a slow warmup. So if it's bad, it would have to fail in the opposite way; slow opening. It's a cheap part and easy to replace, so it's worth a shot, I think.
Had a thought on the air bubbling you saw in your PS reservoir. Could there be a leak on the suction side of the PS pump?... in a hose or fitting? The pump would suck in air and possibly not spin the fan as fast as it should. And an air leak could be a here-today-and-not-tomorrow sort of problem, depending on how big it is. I know it's a bee-atch to get a good look down there.
Old 09-03-2008, 02:00 AM   #13 (permalink)
just a nobody
Have you ever had the thermostat replace before? You do have quite a few miles on your car, won't hurt replacing it if you haven't done it before. Poor circulation can also cause it to heat up faster too.
N.E.O.
Old 09-03-2008, 07:39 PM   #14 (permalink)
The mileage is in my sig. Ive only had the car for a few months now. Ive not replaced the thermostat and Im not sure if the person before has or not.
Old 09-04-2008, 03:42 PM   #15 (permalink)
View fadumar's Photo Gallery
your car became hard to steer when the coolant got on your ps belt causing it to slip.
fadumar is offline   Reply With Quote
