Yes, Ithink you should reconsider your decision. Once again, why do you want to replace the pulley / harmonic balancer?
If the original pulley was very heavy, like cast iron, it was made heavy for a reason, to dampen out engine roughness and shaking. Replacing with a much lighter unit will throw the balance of the engines rotating mass off and all sorts of bad things can happen. If the pulley WAS just a stamped steel unit and fairly light, changing to a even lighter aluminum unit will not do anything for you in terms of performance except reduce the cars weight by a few grams, big deal. If you want performance, this is not the place to look.
