IF yours is like mine it is put on with a big patch of 3m tape at each end, no nuts on the bolts... you will have to remove it to replace the leds i believe (mine is off and in pieces for paint) the best way to do it is use something like thin speaker wire, tie it around the plug, undo the 4 screws holding the lower plate on, take off the three holding in the led bar. slowly and carefully pull the wire out the out the hole with the speaker wire trailing behind, un plug it at the plug that is about half way down the length between the light and the side of the spoiler, get you new bar, plus in the 2 wires,tie the other plug to your speaker wire and pull it all back thru, put on some new 3m tape (and or nuts on the spoiler bolts) plug everything back and your done.
