Camry overheating with new head gasket - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2008, 03:58 AM   #1 (permalink)
View louef's Photo Gallery
Hi all,
I bought a 1994 Camry 4 cylinders 2.2L 318k a month ago and since I have it, it is overheating.
Here what I have done:
-Head gasket (didn’t do pressure test or planning but was hoping it was just
the gasket, I was so old and everything was white)
-New cooling fan switch (was also bad)
-New Thermostat from the dealer (didn’t have any)
-New radiator (the upper plastic tank exploded on idle test after head
gasket)
-Rad flush + new coolant
Here what it does:
- Overheat really fast, the thermostat doesn’t open easily and bottom of the rad is not so hot.
- Without the thermostat: still overheat, fans turns on for 20 sec when close to red and the temp. stays the same.
- Without thermostat with fans always on: temp stay below half and doesn’t overheat.
- No heat from heater
- No bubbles from the radiator cap opened when cold but when hot it overflows
- No white smoke or coolant in oil, coolant level appears to stay the same
- Doesn’t overflow from overflow bottle but I can see some bubbles
I am about to do the water pump or buy a rebuilt cylinder head
Please Help
louef is offline   Reply With Quote
Old 09-03-2008, 04:18 AM   #2 (permalink)
just a nobody
Have you check to see if the coolant is actually circulating? It maybe a circulation problem that you are having.
N.E.O.
Old 09-03-2008, 06:07 AM   #3 (permalink)
N.E.O.
I see it circulating in the radiator without the thermostat but hard to tell if the circulation is good or not
Old 09-03-2008, 08:06 AM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
boil test the Tstat in a pan to see if you got a bad one.
Did you install thermostat the right way with jiggle pin up?
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 09-03-2008, 08:31 AM   #5 (permalink)
Tstat is good and jiggle pin up
thanks any other ideas
Old 09-03-2008, 08:53 AM   #6 (permalink)
View uraverageyota's Photo Gallery
circulation problem, waterpump impeller may be slipping on shaft or corroded away. Did you bleed all the air out of the cooling system? sometimes they can be a problem make sure upper hose is held down a bit while filling radiator
uraverageyota is offline   Reply With Quote
Old 09-03-2008, 09:14 AM   #7 (permalink)
That is my guess, I will remove it tomorrow thanks
Old 09-03-2008, 12:07 PM   #8 (permalink)
just a nobody
If I remember correctly you might be able to see the impeller of the water pump with the thermostat out, but I am not 100% sure. Either way, it beats taking the water pump off to find out it is something else.
N.E.O.
Old 09-04-2008, 08:40 PM   #9 (permalink)
View proftomda's Photo Gallery
USA
I agree. If your thermostat checks good you either have air in the system or your water pump is defective.
If able, do a compression test on the engine to verify a good cylinder head to block bond. Was the head surface machined or was a new gasket simply installed? the goal of the compression test is to see even numbers across all cylinders, thereby telling you that you have a good seal between head and block.
proftomda is offline   Reply With Quote
Old 09-05-2008, 03:09 AM   #10 (permalink)
N.E.O.
You are right N.E.O. we can see the impeller from the T-stat hole
and it was definetely bad
Thanks ALL
Old 09-05-2008, 03:15 AM   #11 (permalink)
just a nobody
That is definitely a BAD one.
Glad you found your problem.
N.E.O.
