My driver's window stopped working in the open position. It was stuck in the open position yesterday and early this morning, then suddenly we were able to close it. We will leave it closed until we can fix this problem. About 2 1/2 years ago we had the exact same problem. I had the window motor replaced with an after market part, but the window regulator was not replaced.
The local Toyota dealer thinks it's the window regulator or window motor, or both. He doesn't think the problem is the window module because all the other windows work OK, however it seems that if a button is going to malfunction, it is likely to be the much more used driver's window control.
Toyota wants $600 to diagnose and replace the window motor and window regulator.
I am considering getting salvaged parts through the automotive part search engine,
www.uneedapart.com and have the parts send by overnight delivery and have my mechanic install them. I am considering ordering all three: the window motor, regulator, control module.
Does anybody have any wisdom to shed on this predicament? Should I replace all three parts? These sporadic problems are sometimes the hardest to solve and as such, maybe all three parts should be replaced to make certain that I am solving this problem.
