3VZ-FE V6won't stay on after being started - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2008, 10:08 AM   #1 (permalink)
View SamMan23's Photo Gallery
Alright, the car is a 1993 ES300/Camry V6. After starting, you have to keep your foot on the gas to keep it going. If you let off, it dies. I was able to drive it(stick shift) amazingly till I got home. Then it would stay on and not die. What could be wrong? I think it may be a IACV, EGR, Coolant Temperature Sensor. Does anybody have any suggestions?
ToyotaSamChen@hotmail.com
SamMan23 is offline   Reply With Quote
Old 09-03-2008, 11:43 AM   #2 (permalink)
Local Rape Machine
View ekim55121's Photo Gallery
have you checked to see if the maf sensor is functioning? i would unplug it and spray some contact cleaner on the inside of the maf and also the connector first and then try.
ekim55121 is offline   Reply With Quote
Old 09-03-2008, 12:12 PM   #3 (permalink)
btw, the check engine light is not on.
Old 09-03-2008, 12:46 PM   #4 (permalink)
just a nobody
My guess would be on the EGR or IAC? Tap the EGR with a screw driver handle and see if it help.
N.E.O.
Old 09-03-2008, 01:02 PM   #5 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
X2. I had a very similar problem a couple of months ago, ended up being my MAF sensor crapped out on me.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 09-03-2008, 03:44 PM   #6 (permalink)
View llcoolpass's Photo Gallery
intake hose, between the air flow meter and the intake throttle body, has NO not even one little hole , right?
1993 Lexus ES 300 [completely stock] -- 5-speed Manual V-6 3VZ-FE -- Curb Weight 3,570 lbs; Mileage 152,000 -- 0-60mph http://www.youtube.com/watch?v=ygwUh1MZRLM
llcoolpass is offline   Reply With Quote
Old 09-15-2008, 12:49 PM   #7 (permalink)
this is a really weird problem. but it has not happened since.
Old 09-15-2008, 06:54 PM   #8 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
Could be an intermittant short within your Air Flow Meter or in the wiring to it. Just keep your guard on.
BlueFusion6851 is offline   Reply With Quote
Old 09-15-2008, 07:06 PM   #9 (permalink)
just a nobody
A problem with the air flow meter would usually set a code if there is any problem, but who knows, it is not acting up right now.
N.E.O.
Old 09-21-2008, 12:52 PM   #10 (permalink)
Local Rape Machine
remove the connector from the maf and spray in some di electric grease or contact cleaner just in case there's a bit of moisture in there.
2001 Avalon
1996 Camry
1988 Supra
1996 Corolla R.I.P
2005 Beetle (Work Car) Lease Up! 2009 Beetle
Old 09-21-2008, 02:47 PM   #11 (permalink)
engineer in training
Gameroom cash: $145055
The 3vz uses a flap style volume air flow meter, not a MAF.
More than likely the idle control components located on the throttle body have become gummed up over the years, you may need to disassemble the throttle body assembly and clean all the ports as well as the EGR valve setup. All these components work together and if one fails it can cause a multitude of symptoms.
