97 Camry 5S, engine suddenly loud - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2008, 10:35 PM   #1 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $294873
View Buurin's Photo Gallery
Dad told me his 97 Camry 4cyl is suddenly loud and thought it was belt. It was not; when I heard it myself it sounded like a ricer installed a fartcan or an intake, so I'm suddenly rice! I have none of those but its exhaust does sound like that, plus some rattling at idle. I drove it around the block and it sounded like that all the time, but not as bad when car is coasting, whatever that means in a auto tranny.
It certainly sounds like a leak, now I need to pinpoint it. What I need to know is how to tell an intake leak from an exhaust leak from a vacuum leak. The following may help if anyone is willing to give me some pointers: (In case no one noticed, yes I'm having fun with my toy)
No CEL (yet)
Idle went as low as 680-690 rpm. cf. 750rpm normal idle.
Bank 1 O2 sensor 2 reads 0.05V idle; sensor 1 swings from 0.01 to 0.95 - seems pretty normal.
Short term fuel trim bank 3 between -1.6 to +14.1
Short term fuel trim bank 1 between -9.4 to +6.2
I smell exhaust from under the hood, near bottom of exhaust heat shield, a little bit off to driver side
I took apart the intake for a cleaning and to gain access to the diff fill plug, but I did reinstall everything tight.
Need help quieting down this big piggy's grunting (oink) , TIA
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 09-03-2008, 10:45 PM   #2 (permalink)
View unkit's Photo Gallery
Have a look where the engine pipe joins the exhaust manifold....
I know its a stab in the dark, but when i had to fork out for a new engine pipe, i was told that this was the most "common" point for my car.
unkit is offline   Reply With Quote
Old 09-03-2008, 11:16 PM   #3 (permalink)
View scoprius's Photo Gallery
My 93 V6 had the same problem, I have a hole about the size of a dime rusted right through my exhaust just after my catalitic.
scoprius is offline   Reply With Quote
Old 09-03-2008, 11:26 PM   #4 (permalink)
just a nobody
Exhaust usually have kind of a roaring type sound, and vacuum leak is more of a hissing type sound and usually not as loud.
N.E.O.
Old 09-05-2008, 08:52 AM   #5 (permalink)
Beware of pigs
Buurin's Avatar
Yesterday night I looked at the exhaust and found damage on the flex pipe, a plastic race covering the brake and fuel lines warped, and scary rust on what looks like brake and fuel lines . So there were 4 possible leak spots - downpipe gasket, flex pipe, cat gasket, near resonator. Torch is required for everything except the downpipe gasket so it has to go to a shop anyway.
This morning the shop confirmed a hole through the flex pipe which is a $650 fix, ouch I pushed for a stainless steel catback but folks don't want to go through the trouble .
Strange that car is still not tripping any code 'cording to my DashDyno, given where the leak is.
Thanks guys.
Buy my parts
Buy my other stuff
Old 09-05-2008, 02:16 PM   #6 (permalink)
_
Gameroom cash: $221635
View uuuuu's Photo Gallery
Flex pipe for $650 on a 4 cylinder? See if you can go to an exhaust/muffler shop and have them weld in a new flexpipe. I got mine done for $130.
uuuuu is offline   Reply With Quote
Old 09-05-2008, 02:19 PM   #7 (permalink)
just a nobody
$650, are you in Cal? I think the Cal spec vehicles have a cat on the front pipe.
N.E.O.
Old 09-05-2008, 05:50 PM   #8 (permalink)
O-Dark-30
frenum49's Avatar
View frenum49's Photo Gallery
$650?????????!!!!!!!!!!!!!!! For a flex pipe? Find a new mech.
frenum49 is offline   Reply With Quote
Old 09-05-2008, 09:57 PM   #9 (permalink)
Beware of pigs
Buurin's Avatar
I'm not in Cal, but my fed-spec piggy does have a cat on the front pipe. Factory manual doesn't say where to cut and weld unlike my Corolla if that mean anything at all.
1sttoyotaparts quotes $92x for that same piece, so it seems fair, and...
... folks don't want to go through the trouble even though I raised this possibility. He just bought $500 worth of convenience which is disheartening. Last time my Corolla went to that shop is for safety inspection for assuming its ownership.
Buy my parts
Buy my other stuff
Old 09-05-2008, 10:09 PM   #10 (permalink)
just a nobody
Glad to hear you got the car taken care of for your folks.
N.E.O.
