00 camry - What is FCC # for keyless entry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-04-2008, 05:39 AM   #1 (permalink)
View solidg's Photo Gallery
4th Generation 00 camry - What is FCC # for keyless entry?
I lost both of my keyless entry remotes. Does anybody know the fcc number of the remote?
I want to buy a new one online. There is 2 different ones? I dont know which one I need to get. That is why I need the Fcc number.
solidg is offline   Reply With Quote
Old 09-05-2008, 07:26 AM   #2 (permalink)
anyone?
maybe ill search ebay?
Old 09-05-2008, 07:43 AM   #3 (permalink)
just a nobody
A dealer can probably answer that question for you, not many people will pay attention to the number on their remotes. Wouldn't hurt calling the dealer and ask, they might be nice enough to give you the number even if you are not buying.
N.E.O.
Old 09-05-2008, 08:00 AM   #4 (permalink)
Indy Tech's Avatar
View Indy Tech's Photo Gallery
UK
Just go to the Dealer and buy a new remote and the reprogram it yourself and save 100 bucks ,Just follow the steps below
1. Start with key out of the ignition, driver door is open (all others closed),
and driver door is unlocked.
  • Insert key into the ignition (don’t turn it) and pull it out
  • Perform these steps within 40 seconds:
a. Using the power lock switch on the driver’s door, perform 5 lock/unlock cycles starting
with lock.
Use an even pace and try to go about one cycle per second. 1 cycle = 1 lock and 1 unlock)
b. Close, then open driver’s door.
with lock.
Use an even pace and try to go about one cycle per second. (1 cycle = 1 lock and 1unlock)
b. Insert the key in the ignition cylinder.
c. Turn the ignition to ON (as far as you can without cranking the engine) then back to OFF.
d. Turn the ignition to ON (as far as you can without cranking the engine) then back to OFF.
e. Remove the key from the ignition.
  • Within 3 seconds, the power door locks should cycle automatically indicating successful entry
    into programming mode.
    Return to step 1 if the locks do not cycle at this point.
a. Press the lock and unlock buttons on the transmitter simultaneously for 1 second.
b. Immediately after letting go of the lock and unlock buttons, hit the lock button by itself and
hold for 2 seconds. Within 3 seconds, the door locks should cycle once indicating successful
programming.
If the door locks don’t cycle, or cycle twice, repeat steps a and b-your remote has not
been accepted.
c. Repeat steps a and b in step 6 for each new transmitter.
7. Close driver door.
Hope this helps you out
Indy
Indy Tech is offline   Reply With Quote
Old 09-05-2008, 09:35 AM   #5 (permalink)
thanks for the re
I want to get one online.
The dealer is like talking to scrooge (sp)?
Old 09-05-2008, 09:33 PM   #6 (permalink)
View pmohr's Photo Gallery
Stock remote for my '01 is GQ43VT14T (verified here: https://gullfoss2.fcc.gov/eas/GetEas...'GQ43VT14T' )
pmohr is offline   Reply With Quote
Old 09-06-2008, 07:35 AM   #7 (permalink)
i appreciate it
now i know
