Upgrade Wiring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-04-2008, 06:08 PM   #1 (permalink)
Noob Camry Owner
hoyota's Avatar
View hoyota's Photo Gallery
Upgrade Wiring
So I'm looking to upgrade "The Big Three" wires under the hood (alt. to battery, battery to ground, and alt to ground) but I have a few questions.
How big of wire should I use? Do I need to use 1/0 Gauge, especially if i have an audio system using 2ga wire?
And how big of a fuse will I need between the alternator and the battery?
Thanks if anyone has answers.
hoyota is offline   Reply With Quote
Old 09-05-2008, 12:20 AM   #2 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
If memory serves, I believe there's a thread somewhere on TN about doing this.
cykaaro is offline   Reply With Quote
Old 09-05-2008, 12:28 AM   #3 (permalink)
xet
View xet's Photo Gallery
there is in the audio section but really wiring is up to you. bigger is always better but go by your budget and what you are comfortable working with.
how much power are you running to your audio??
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 09-05-2008, 05:35 AM   #4 (permalink)
Noob Camry Owner
hoyota's Avatar
I found the thread describing how to do this, but it didn't mention what size wire would be adequate, it only mentioned 1/0, and thats really huge.
I would be running up to 100 amps to the audio system, and that needs some big cable too.
Old 09-05-2008, 07:37 AM   #5 (permalink)
groovemasterodi's Avatar
View groovemasterodi's Photo Gallery
100 amps? @_@
I need to do this too to my baby, the Duralast and stock wiring aint cutting it.
2001 Camry..5FSE..
groovemasterodi is offline   Reply With Quote
Old 09-05-2008, 12:22 PM   #6 (permalink)
xet
well most people do at least 4 gauge, if you are running 2 all around i would at least use 2
2005 G35 coupe 6mt
Old 09-05-2008, 02:13 PM   #7 (permalink)
Noob Camry Owner
hoyota's Avatar
well i mean the fuses would be rated at over 100 amps, probably not the actual continuous power consumption. That would be crazy.
Old 09-05-2008, 06:29 PM   #8 (permalink)
I see this now, i was a tad blazed.
2001 Camry..5FSE..
Old 09-05-2008, 06:48 PM   #9 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Why the hell do you need to upgrade the OEM wires? There is no need. Save your money and invest it in a mod they you can use more.
Also, your burn out your Alternator before you burn out your wires, so I'd upgrade the Alt.
5 Lug Corolla WHAT?
Old 09-05-2008, 10:33 PM   #10 (permalink)
This is what must be done, there is so much wishy washy info on this subject, I needed a good telling
2001 Camry..5FSE..
Old 09-06-2008, 12:05 AM   #11 (permalink)
xet
ive never heard that argument that adam used. from everything ive seen the big 3 is the easiest, cheapest, and first mod to do when upgrading an audio system. it isnt replacing original wiring if thats what you meant, it is simply adding additional wiring to help deliver and recycle the extra power.
i dont know how much power you are sending but if you are sending a lot a HO alternator should be on your list as well. I believe the highlander one or something close fits the camry
2005 G35 coupe 6mt
Old 09-06-2008, 12:54 AM   #12 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
He's got the 5S so the HIghlander alternator isn't going to work. Pretty much it's going to be a custom built alternator to generate the current he needs.
2007 Camry 2.4L 5M
Old 09-06-2008, 10:27 AM   #13 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
i am still lost about what year highlander i should look for when at the junk yard.. yeah i know to look for the one with the 1mz but does any 1mz highlander alt will fit? just want to clarify before i go out and ripp one out...
but yeah a custom alt will make your wallet a bit much lighter then you would expect.
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 09-06-2008, 12:37 PM   #14 (permalink)
I doubt the 1MZ alternator will fit directly on your 5S. You can try to find a Sienna or Highlander with tow package. I *think* they have upgraded transmissions coolers also, so that might be one indicator of a tow package.
2007 Camry 2.4L 5M
Old 09-06-2008, 02:14 PM   #15 (permalink)
I've looked into the search for a HO alternator, for those with my Camry, http://www.mralternator.com/main.shtml seems to be about all I can find, and have heard good things from them.
2001 Camry..5FSE..
