Buying a used Gen 4 - get the V6 or the I4? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-04-2008, 09:39 PM   #1 (permalink)
View fonebone's Photo Gallery
I'm looking at Gen 4 Camrys with < 70k miles. So far the top contenders are a 2001 CE with 52k miles and a 2001 LE V6 with 67k. The CE has a lot of options (no keyless entry, but no problem to add that later, right?), though the LE has traction control and of course the more powerful engine. I will only need the car for 2 years or so, but I plan to put 20k -30k miles/yr on it during that time.
I'm hoping to do mostly highway driving with the car and I'm mostly concerned about the mileage difference between the two engines. Some people seem to think that the difference isn't very significant. I drive pretty conservatively, use cruise control religiously, and plan to keep it around 75 on the highway.
fonebone is offline   Reply With Quote
Old 09-04-2008, 10:17 PM   #2 (permalink)
View toyomoho's Photo Gallery
There have been posts on the MPG difference between I4 and V6, suggest a TN search. The I4 will get 26-27 MPG overall, around 35 if X-country. It uses regular gas.
If driving on flat lands and the car is not overloaded with weight the I4 will do nicely and cruise at 75 MPH with no problems. The I4 is also easier to work on and may have more resale value given the smaller engine and higher MPG.
If you need more power get the V6, it should get around 21 MPG overall and may require 91 octane.
Old 09-04-2008, 10:27 PM   #3 (permalink)
xet
View xet's Photo Gallery
I would say v6, i had/have a 98 v6 and it has never used anything but regular for 150k miles with no problems. gas mileage is also very good and i can get mid/high 20s average and even better just cruising at highway speeds.
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 09-04-2008, 11:01 PM   #4 (permalink)
Noob
View gladis's Photo Gallery
If mpg is your main concern, then go with the I4, without a doubt. I would pick the V6, since it's a nicer package overall, but like toyo said, the I4 is easier to maintain, and will undoubtedly give you better mileage (you should expect ~30-32 if you do all highway ~75)
1996 Toyota Camry LE 2.2 - 139xxx 162xxx
2000 Toyota Sienna XLE 3.0 - 82xxx 104xxx
08/08 08/11
gladis is offline   Reply With Quote
Old 09-04-2008, 11:45 PM   #5 (permalink)
Do not buy from
View Zviator's Photo Gallery
either I4 or v6 wont put u in the same class with GTs or SEs, so go for I4 and spit on others at the pump, lol.
Zviator is offline   Reply With Quote
Old 09-04-2008, 11:50 PM   #6 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
I would take the V6 since you are driving in the highway most of the time the extra power could make a difference for an emergency...
Take the V6 when mostly driving highway the V6 and I4 are not that far apart in mpg from what I seen.
felonyr301 is offline   Reply With Quote
Old 09-05-2008, 12:27 AM   #7 (permalink)
xet
^i agree
i can easily get 400+ miles per tank with mixed driving. my dad who i dont understand how he gets such great mileage drives more freeway than me but gets more like 500 miles per tank. That puts you right up close with the i4 and you have a much more powerful engine.
2005 G35 coupe 6mt
Old 09-05-2008, 03:03 AM   #8 (permalink)
View blainer's Photo Gallery
I'd get the V6 if its mainly highway. I personally love the mid-range punch you get with it. I own both I4 and V6 gen 4s, and both of them have pros and cons. On the highway, the I4 is great for crusing but it don't got much punch sadly. On the other hand, the V6 will just pull you away and leave you with a nice exhaust note as a touch!
1996 Camry Coupe 5S-FE 5spd
Stock at the moment. 123xxx mi
blainer is offline   Reply With Quote
Old 09-05-2008, 04:27 AM   #9 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
they both have good gas millage, the actuall differance on the highway isnt much since at higher speeds the v6 works less to speed up or just cruise but in the city is the big differance. if your just using this as a DD commuter car and jsut plan to sell it in a couple years then id get the I4. hundreds of thousands of people get by jsut fine with it and so can you.
however, the gen4 I4 was prone to engine sludge so have that checked if ya can before purchasing or at least find out if it was properly maintained.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 09-05-2008, 05:44 AM   #10 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $907927
iTrader Score: 59 reviews
I've owned both and I agree with all comments stated above.
I personally prefer the V6....the slight decrease in MPG is a small price to pay for the extra power. They just seem to drive better IMO.
1MZ FTW
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 09-05-2008, 06:21 AM   #11 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
If you live in an area where there are a lot of hills, you will definitely appreciate the V6. However, I noticed you're from Chicago, which is pretty flat.
I usually get 26-27 MPG mixed driving with my 4-cyl. On steady highway, I can get 33 MPG.
Go here and you can compare fuel economy and annual fuel costs between a 4-cyl & V6 Camry.
http://www.fueleconomy.gov/feg/findacar.htm
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 09-05-2008, 06:14 PM   #12 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
What is the price difference between the I4 CE and V6 LE?
Personally, I would go with the V6 but you really can't go wrong with either. In my view, LE trim + V6 + TC will help resale value but as it's already been mentioned..those who are concerned with gas mileage will only look at I4s. I like the V6 because it's easier to drive on the highway when you're merging or changing lanes; it doesn't require as much thought (can I make it?) and the 1MZ is just a smooooth engine overall.
Test drive both and pick the one that drives/feels/looks better.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 09-05-2008, 06:59 PM   #13 (permalink)
View Albuynp Ryeno's Photo Gallery
The v6 is def better on hills but thats not really a concern for you. What it really comes down too, is how do you drive?
I'm a risky driver, like everyone here in la. The v6 gives you better acceleration which is really useful IMO. Also the rear disc brakes on the v6 provide better breaking, especally at highway speeds.
I have both the 5s-fe and the 1mz-fe. Whoever said the gas millage is similar on freeways is right. Its very weird. In city is terrible milage but highway is great.
I personally like my v6 a lot more.
1995 Camry V6 LE - Sold
1998 Camry LE
1992 SC300 5SPD
1992 SC400
Albuynp Ryeno is offline   Reply With Quote
Old 09-05-2008, 11:34 PM   #14 (permalink)
View chullen's Photo Gallery
personally I own a 1999 LE V6 and would go with that I use nothing but 87 octane with the occasional tank of 93. It is better for hills and helps if you need to pass someone
1999 Camry V6 5 spd- Daily Driver
2006 Civic Si 192 whp- SOLD
1986 Corolla GTS 250 whp- SOLD
1996 Accord EX- SOLD
Production Team Leader at Mercedes Benz
chullen is offline   Reply With Quote
Old 09-07-2008, 03:14 PM   #15 (permalink)
via.reality's Avatar
View via.reality's Photo Gallery
dood get an i4... ihave one and its slo az fukk but i live in miami, FL. crazy place and i pump 50 buks of gas every 7 days.
the v6 might b able to keep up with sum altimas and maxima's but never lik an srt4 or a gsr.
so think economical...and mine still looks nice.
01 camry chillin in miami
<a href="http://s16.photobucket.com/albums/b2...18562c87-1.jpg" target="_blank"><img src="http://i16.photobucket.com/albums/b2...18562c87-1.jpg" border="0" alt="Photobucket"></a>
via.reality is offline   Reply With Quote
