Offtopic camry 1994 steering shake at 55 mph to 60 mph - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-06-2008, 10:28 PM   #1 (permalink)
View jdmcamry703's Photo Gallery
Unhappy Offtopic camry 1994 steering shake at 55 mph to 60 mph
1994 LE V6 Camry with 150k miles. It started to develop a shake that is only during acceleration and only between 55 and 60 mph. Replaced front rotors and front pads, pair of control arm with balljoint. I can't seem to find the problem but we did alightment and front left is bad alightment but otherwise when driving 70mph it doen't shake, it only shake in 55 to 60 mph, what is the actual problem?
jdmcamry703 is offline   Reply With Quote
Old 09-06-2008, 11:07 PM   #2 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Wheel balance. If they are not balanced properly, you can feel it at certain speeds but not others.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 09-06-2008, 11:39 PM   #3 (permalink)
hajimemashite
Japan_Racer's Avatar
View Japan_Racer's Photo Gallery
gen 7
yeah or its a shimmy...or maybe ur alignment is off..bcuz my 96 corolla did the same ting...mine was a shimmy...but i not sure if its on urs
Japan_Racer is offline   Reply With Quote
Old 09-07-2008, 12:29 AM   #4 (permalink)
vL
92Camry5sp's Avatar
Gameroom cash: $219005
iTrader Score: 6 reviews
View 92Camry5sp's Photo Gallery
can be your axles are going out also.
92Camry5sp is offline   Reply With Quote
Old 09-07-2008, 01:18 AM   #5 (permalink)
Radio, this is Unit 91...
eurohazard's Avatar
View eurohazard's Photo Gallery
It does sound like tire balance problems.
1993 Camry LE 5SFE AT, 2006 Nissan Armada LE 4x4, 1971 Cadillac Coupe DeVille "pimp juice"
Toys: 2007 Coachmen 19FLB, 2007 Regal 1900 V6
I'm the biggest boss thatchu seen thus far! Baby, that's muh wi'zzard!
eurohazard is offline   Reply With Quote
Old 09-07-2008, 03:01 AM   #6 (permalink)
View blainer's Photo Gallery
Had that happen on my Gen 4 and its the CV joint boot being torn.
1996 Camry Coupe 5S-FE 5spd
Stock at the moment. 123xxx mi
blainer is offline   Reply With Quote
Old 09-07-2008, 01:46 PM   #7 (permalink)
TheKevin's Avatar
View TheKevin's Photo Gallery
your wheels need to be balanced. get it done asap because it can lead to bigger problems.
TheKevin is offline   Reply With Quote
Old 09-07-2008, 04:25 PM   #8 (permalink)
Gameroom cash: $303255
If wheel balancing doesn't solve the problem, here's a quick test you can do with the help of another person. Jack up the front end of the car and support it safely on jackstands. Now have the other person get inside the car and start it and place it in drive. Have that person accelerate the car slowly to the speed where you feel the problem happening. You get down on the ground in front of the car and watch the axles and the wheels. Look for signs of either being bent or out of round. Just be sure to support the car safely on the jack stands before doing this.
Mike
Mike Gerber is online now   Reply With Quote
Old 09-07-2008, 06:16 PM   #9 (permalink)
View camry314's Photo Gallery
If you can try going to Discount tire(I am not trying to plug them) but they do a road force balance where they can tell you if its the tire that might be bad even though the wheel/tire combo might balance out. I had a bad tire and was only able to find that out after doing the road force balance. It is much more than just rotating mass, like most balancers.
camry314 is offline   Reply With Quote
Old 09-08-2008, 04:26 AM   #10 (permalink)
slowamatic noob
a94autoCamry's Avatar
Gameroom cash: $149910
View a94autoCamry's Photo Gallery
i had this problem before, and one of my axles was bad...so check for that
slow white - "no show and no go"
a94autoCamry is offline   Reply With Quote
