speaker replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2008, 01:46 PM   #1 (permalink)
View alcornnw's Photo Gallery
3rd Generation speaker replacement
I need to replace the front door speaker in my 1992 Camry, and my question is do I need to remove the door panel to get to it, or can I just remove the speaker grill?
alcornnw is offline   Reply With Quote
Old 09-07-2008, 01:47 PM   #2 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
yes, the door panel needs to be removed.
TheKevin is offline   Reply With Quote
Old 09-07-2008, 06:35 PM   #3 (permalink)
View camry314's Photo Gallery
Not to tread jack, but will a 6x9 drop right in the back or does that take a bit of trimming to fit?
camry314 is offline   Reply With Quote
Old 09-07-2008, 07:04 PM   #4 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
Here's a thread that deals with door handle replacemant, but it has great info and pics of door panel removal. It should help you get to the speakers.
DIY: Interior Door Handle Replacement (GEN 3)
It will require you to cut the metal, because the oem speakers have a 3 point mounting pattern. Aftermarket speakers of course have a 4 point mounting pattern. You could trim the metal, but you could save alot of time and effort if you just buy 6x9 adapters for the new speakers. That's what I did. The adapters needed a bit of trimming, and after that, it shouldn't take more than 15-20mins total for the install.
http://cgi.ebay.com/ebaymotors/_Car-...=p4506.c0.m245
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 09-07-2008, 08:18 PM   #5 (permalink)
okay, what if i only want access to the speakers,and not replace them.is it poo]ssible to just remove the grill, and if so, how?
Old 09-07-2008, 08:33 PM   #6 (permalink)
uibalnme's Avatar
The best way to get to the speakers is to remove the door panel.
Now here's my question, if you don't want to replace the speakers, why do you need access to them?
Old 09-07-2008, 09:20 PM   #7 (permalink)
i need to get to them to access the db switch on them. it helps control the level of balance of the front and rear speakers.
Old 09-07-2008, 09:25 PM   #8 (permalink)
uibalnme's Avatar
Isn't that controlled from the stereo? Last time I went into the doors, I never saw any swtich that did that. I've always been able to control the front/rear balance (a.k.a. fade) right from the stereo, stock or otherwise.
Old 09-07-2008, 10:05 PM   #9 (permalink)
well, it is on my speakers.........infinity 6022 6 3/4" 2 way. it gives the speakers more brightness insound
checkout the website
Old 09-07-2008, 11:27 PM   #10 (permalink)
uibalnme's Avatar
So, then you're talking about the crossover, and the frequencies that are sent to the woofer and tweeter.
That means that the speakers have already been replaced.
