how to clean this motor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2008, 10:40 PM   #1 (permalink)
View jscollins's Photo Gallery
Unhappy how to clean this motor
When i first start my car it smokes really bad i have no clue what it is. I need to get this car to pass inspection so i can drive it i took all the 2.5% tint off of it cause i could not see while driving at night lol. I was wondering if it was cause to motor looks dirty but it does not smoke from under the hood, it comes out of the muffler and i smokes until i punch the gas. I got a pic of the motor and i need to know if this is the problem and how toy clean it if so.
jscollins is offline   Reply With Quote
Old 09-07-2008, 10:46 PM   #2 (permalink)
JEV
one man crew
JEV's Avatar
View JEV's Photo Gallery
not sure but i'm just guessing could it be the pcv valve, maybe it's it's sucking in oil.
teacher check it by inserting a thin stick in the tube if it's oily your sucking in oil. maybe the valve guides are worn and sucking in oil from vacuum. check those.
or maybe a simple engine cleaner(the one that cleans the insides).
JEV is offline   Reply With Quote
Old 09-07-2008, 10:52 PM   #3 (permalink)
It did not do it untill i got the oil changed at jiffy lube they put like 5 quarts of oil in my 4 cylinder motor
Old 09-07-2008, 10:53 PM   #4 (permalink)
rty
Gameroom cash: $298766
View rty's Photo Gallery
The engine will not smoke simply because the outside of the engine is dirty. Does it smoke when you hit the gas?
rty is offline   Reply With Quote
Old 09-07-2008, 11:02 PM   #5 (permalink)
when i 1st start it it smokes really bad. when i push the gas for a while it stops. ok say i take it down u road which is 1 mile long, when i hit about the 1/2 mile mark it stops.
Old 09-07-2008, 11:30 PM   #6 (permalink)
just a nobody
Does it continue to smoke after it is warmed up?
N.E.O.
Old 09-07-2008, 11:46 PM   #7 (permalink)
N.E.O.
if i turn it off for like 1 minute yes
Old 09-07-2008, 11:57 PM   #8 (permalink)
just a nobody
What about if you just leave it running? Does it continue to smoke if you don't turn it off? Any smoke during acceleration? Light throttle? Heavy accel?
N.E.O.
Old 09-08-2008, 02:46 AM   #9 (permalink)
View tran.man48's Photo Gallery
run some seafoam through the vacuum line and pour 1/3 into the crankcase.
Search for "seafoam" on here for more info...
Originally Posted by Zembonez View Post
Nothing is impossible with enough money and beer.
tran.man48 is offline   Reply With Quote
