basic steel rim question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-08-2008, 02:00 PM   #1 (permalink)
i go both ways-mac and PC
ghettosled's Avatar
Gameroom cash: $128595
i re-did the brakes on my car the other night and noticed something strange with one of my rims. the hole in the center is much large than the rest of my rims. i cant believe that i havent noticed until just now. i have literally 9 steel camry rims (set of 4 on the car, one spare, and then a set with mounted snow tires) and only 1 has this larger hole. here is a pic of a 'normal' rim
and here is a pic of the enlarged hole
notice the gap between the hub and the rim. can anyone explain what vehicle this rim may be from and if it would cause any problems (which i doubt it will).
Old 09-08-2008, 02:24 PM   #2 (permalink)
View djb2's Photo Gallery
Yes, it will likely cause a problem. The wheels are hub-centric. The raised ring around the hub precisely centers the wheel. You are likely to have the wheel a little off-center each time you mount it, resulting in imbalance and vibration. Once clamped down, the metal-to-metal friction carries the normal load, but the hub still may come into play with extraordinary loads or if the lug nuts loosen.
Using the wrong wheel is unsafe. It's especially foolish since you have a few of the correct wheels.
djb2 is offline   Reply With Quote
Old 09-08-2008, 03:20 PM   #3 (permalink)
View jaybur_racing's Photo Gallery
I wonder how many people with after market wheels have issues. Many are "universal". and most likely NOT be hub centric. I don't see how that is "un-safe". At worst you might see some balance issues, but I doubt even that.
Unless you are putting 1 lug nut on, and torquing it to spec before installing the other lug nuts, the lug nuts will center the wheel.
94 camry DX coupe 5 speed
MODS: swapped in cruise control
jaybur_racing is offline   Reply With Quote
Old 09-08-2008, 04:08 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $359260
iTrader Score: 13 reviews
lol
that's kinda funny
and lots of people with aftermarket rims have problems...if they don't know what they're doing.
if you have no vibration issues, etc, then just leave it. properly torquing the nuts can usually center the wheel just fine. if in doubt though, it wouldn't hurt to find out what size it is (you can measure it) and pick up a hubcentric ring to make sure that it's centered correctly at all times
HaHa
Old 09-08-2008, 05:01 PM   #5 (permalink)
just out of curiosity, what do you mean "lots of people have problems with after market rims if they don't know what they are doing" ?
I have known many people with after market rims, and see them on tons of vehicles on a daily basis.
so I just want to know what problems people are having.
Old 09-08-2008, 08:01 PM   #6 (permalink)
ghettosled's Avatar
i still wonder the story behind where this rim came from. its almost large enough to fit a 4wd hub through there.
Old 09-08-2008, 10:02 PM   #7 (permalink)
TN Pussy Man
really usually just the lack of a hubcentric ring, since some shops will sell rims to whoever without them
it just causes vibrations usually and is easily remedied
HaHa
Old 09-08-2008, 10:38 PM   #8 (permalink)
Radio, this is Unit 91...
eurohazard's Avatar
View eurohazard's Photo Gallery
That is a different rim obviously. Not only is the whole bigger in the middle, but the rectangular bumps between the lugnuts are peaked more than the plateau ones in the pic#1 wheel.
There shouldn't be a problem with hubcenricity as long as you have proper lugnuts that self center, and assuming you tighten/torque them in the proper sequence.
1993 Camry LE 5SFE AT, 2006 Nissan Armada LE 4x4, 1971 Cadillac Coupe DeVille "pimp juice"
Toys: 2007 Coachmen 19FLB, 2007 Regal 1900 V6
I'm the biggest boss thatchu seen thus far! Baby, that's muh wi'zzard!
eurohazard is offline   Reply With Quote
Old 09-09-2008, 10:58 AM   #9 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
If it isn't causing any problems you could live with it as mentioned above. If you are concerned about it you could use it only for the spare but that might mess up your rotation program. If you seldom use your snow tires you might consider mounting one of them on it.
You've lived with it this long. You could find another "good" one and then sell the odd one on Craig's list or eBay or something. Personally, I would just keep using it.
Kep
