Hi All,
I did the rear brakes (drum) the other day and decided to post some pics on this forum. I adjusted the star-wheel. The handbrake is tight now and the car brakes good.
Sorry for the low budget maintenance/repair, I am a student and have borrowed money from my parents to buy this car. Steps are as follows.
1. Jack up the car securely (you can use bricks and jack togather or better to use jack stand unlike mine)
2. Remove tire
3. Remove drums fairly easy they just slide off once you tap with hammer (all sides).
4. Clean everything inside.
5 Put drum back
6. remove rubber plug and look for that start wheel in hole as shown in pictures. This lies on top in my model under the brake cylider (yellow cricle in photo). repair manual might say it is on the bottom side thats not in my case.
7. Slip in a screwdriver and move wheel downward it will click or might not click if its messed up. DOWNWARD - tightens the brakes. tighten it until when you rotate the hub axle with drum on, you feel the drum has drag to it (brakes shoe are lightly touching the drums but letting it move).
8. dont tighten too much other wise you have to take drum off and lossen it by moving upwards and repeat everythign.
Enjoy working!
Cheers,
Al
