Originally Posted by mykyna
I recently replaced the ac compressor on my 93 SE v6 Camry (160k). However, I found the coolant overfolw tank getting almost empty after I drove two weeks. I kept filling coolant for about 1 gallon but it seems not solve the issue. I don't see any leak on the floor and I sent to the mechanic (the guy who changed my compressor) to check but they could not find any leaking. So far the temperature meter looks normal and not go to red. I am wondering what happened? anyone has this experience? Thanks a lot!
your probobly burning coolant or its gitting into the exhoust or the engine oil check all three. change your oil yourself and loook in the drain pan after your done and if it is discollored or you see a nother liquid you would bee able to tell coolant and oil dont mix and it could also be able to get ito the exhaust through the egr valve it could be any thing any were, any where there is coolant passage there could be a leak and any were in the engine but. oyea check yea trans fluid pull the dipp stick and if it is strabarry milkshake color then your fucked but if it is red or dark red or brown or black that is all the colors of trans fluid. yea let me know what you find.
