What suspension parts to change for Camry 2000? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2008, 09:33 PM   #1 (permalink)
View shet's Photo Gallery
My 2000 Camry with 85000 miles squeaks/creaks (especially the front side) when going over speed bumpers.
Apart from the struts, what other suspensions things would you recommend to have it changed? Things like sway bar or bushing maybe.
Also should I change front and rear suspension at the same time?
shet is offline   Reply With Quote
Old 09-11-2008, 12:08 AM   #2 (permalink)
View toyomoho's Photo Gallery
Start out by checking the sway bar bushings, sway bar end links.
Old 09-11-2008, 08:33 AM   #3 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
I would recommend changing all 4 at the same time. That way you will only need to have it aligned once.
KYBs are quite reasonably priced and are of good quality. I've use them in both my Camry & Maxima.
Make sure you get new strut mounts as well.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 09-11-2008, 07:57 PM   #4 (permalink)
Thanks. Also, I am thinking of buying the parts online and then take it to an auto-shop to have it assembled. So, so far the list is struts, strut mounts, sway bar bushings and sway bar end links.
Old 09-12-2008, 10:12 PM   #5 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
I test sway bar bushings with spraying each with some rust proofing oil one at a time to see which squeaks, if it is none, then look at the strut mounts.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
