hi everybody i dont know wats the problem but, suddenly the handbrake indicator turned on and dont want to turn off ... does anyone know how to fix that thkns
ps. I have a 1993 v6 camry thnks
check ur brake fluid....i can guarantee the fluid in the reservoir is low
2009 Camry SE V6 loaded
Mods: Borla Dual Exhaust with no resonator, K&N Intake, 5k HID headlights and 5k HID foglights, LED Tail lights, Complete interior leds, Ultra Racing Front Strut Bar, Ultra Racing 19mm rear sway bar, 20% tint, Rosen navigation system, 19 inch ASA GT1 wheels
its weird that toyota uses the same brake light to signal if either the parking brake is on or the brake fluid reservoir is low. why couldnt they have seperate lights?
Acura does the same thing. My friend has a Legend and her brake light was on.. We added some brake fluid (it was low) and the light went off. It's an older Legend and it has a separate reservoir for brake fluid for the ABS system. I thought that was odd.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles moving forward
After refilling with brake fluid, have your brake pads checked for pad thickness, some time in the near future. When the fluid in the resevoir becomes that low, it is usually an indication that the brake pads have considerable wear on them. As the pads wear, the hydraulic system has to push them out further for them to contact the rotors. This requiresa more fluid. Hence, when the fluid needs to be topped off because the resevoir is down to the minimum level, it usually indicates considerable pad wear.
Mike
Thanks for the explanation. I was wondering how my friend's Legend was low on brake fluid when there was no signs of a leak. Her brakes started squeaking a little bit a few months ago so I guess it's time for new pads.
I checked my own Camry and the brake fluid reservoir is still full, with the fluid clear and slightly yellow. No squeaky brakes yet. About how long do brakes usually last with city driving? I've got 30K miles on my gen 5.5.
I have the same problem, but I have a full level of brake fluid in the cylinder and the light still won't come off
I can't even use the cruise control because the brake light still on. I had to unplug it from the cylinder to get the cruise control to work again
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
Bad or stuck switch in the reservoir will cause that. Use a screw driver or something, lightly tap the side of the reservoir see if the light will go off.
N.E.O.
Happened to me on the LE. Small screwdriver worked. It's a styrofoam peice in there that floats. It gets stuck sometimes when the fluid gets too low. After I unstuck it, it hasnt happened again.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
That sounds like the same problem with mine, but I tried tapping the reservoir. I could never get it unstuck
