1999 Camry with chirping noise
Hello all. I have just recently purchased a '99 Camry. It is in very good shape and is running well. It has 116k on it so far. Lately, a chirping noise is coming from the passenger side engine area. It is definitely more pronounced when I listen to it from behind the passenger side tire area. At first start in morning, it is quiet and develops to a certain level and stays there. It also seems to be tied to engine rpm. The chirping is similar to a cricket. Steady, but changes a bit with rpm. I do not have any other symptoms as of yet and thought I would ask out here for any ideas. I sprayed water on the belts individually to see if it might show a noisy belt. Nothing changed. The timing belt and other belts were replaced at 68k according to the records. I would appreciate any ideas as to what might be causing it. Maybe it would give me a starting place to investigate. Thank you in advance.
Craig
