98 Camry Timing Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2008, 07:26 PM   #1 (permalink)
r1gal's Avatar
View r1gal's Photo Gallery
Hi-
How do you adjust (set) the timing on a '98 Camry. It has no distributor to adjust, can anyone help me out? I've had several older Camrys, but this is new to me. An help appreciated.
r1gal is offline   Reply With Quote
Old 09-14-2008, 07:28 PM   #2 (permalink)
just a nobody
No adjustment available, timing is ECM control base on input from MAF, Cam Sensor, Crank Sensor and TPS. Oh, and sometimes the knock sensor(s).
Why do you need to adjust the timing?
N.E.O.
Old 09-14-2008, 07:45 PM   #3 (permalink)
r1gal's Avatar
[quote=new echo owner;2481893]No adjustment available, timing is ECM control base on input from MAF, Cam Sensor, Crank Sensor and TPS. Oh, and sometimes the knock sensor(s).
I just put a new timing belt, waterpump, cam-crank,oil-pump seals etc,.
It runs great. I was just wondering. I've had several 92-93's.
Old 09-14-2008, 07:49 PM   #4 (permalink)
just a nobody
They don't need any further adjustment if you have aligned the timing marks correctly. You can check the timing but usually that is for other reasons.
N.E.O.
Old 09-14-2008, 08:29 PM   #5 (permalink)
r1gal's Avatar
N.E.O.
Thanks, NEO!
