Trunk seal leak help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2008, 09:20 PM   #1 (permalink)
Camry LE V6 2001
View REDSOXTICKET's Photo Gallery
4th Generation Trunk seal leak help
I have a trunk leak on the right side caused by water getting under the rubber trunk gasket. The gasket can easily be pulled off on only the right side.
I need your advise on the procedure and materials used to adhere the gasket to the trunk per oem standards or close to it.
What type of adhesive ?
Do you apply the adhesive to both side of the rubber or just the side closest to the drain ridge ?
How do you apply the adhesive ?
Thanks
REDSOXTICKET is offline   Reply With Quote
Old 09-15-2008, 02:05 AM   #2 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
I'd check with your local parts store. They should have some type of sealant specifically for door seals I would think.
cykaaro is offline   Reply With Quote
Old 09-15-2008, 10:55 AM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
i've used a product called "goop automotive adhesive" before to hold some rubber reals in place and seemed to work well.
