Will a 93 Camry door fit on a 96 Camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2008, 12:19 AM   #1 (permalink)
View thisisbrianly's Photo Gallery
My dad's 96 Camry was swiped by a semi the other day, and his passanger side front/rear doors are completely toast.
I found some 93 doors at the junkyard today for cheap, and was wondering if these would fit the 96 Camry. It looks to be the same model, just was wondering if I'll run into any problems trying to put them in.
Thanks!
thisisbrianly is offline   Reply With Quote
Old 09-15-2008, 12:24 AM   #2 (permalink)
Do not buy from
View Zviator's Photo Gallery
It will be a direct fit, no problem.
Zviator is offline   Reply With Quote
Old 09-15-2008, 12:34 AM   #3 (permalink)
blitzer_26's Avatar
View blitzer_26's Photo Gallery
i agree,
just make sure you wire everything corectly... mirrors//speakers etc... pretty straight forward
*R.I.P* '94 CSI CAMRY 2.2L 4CLY
blitzer_26 is offline   Reply With Quote
Old 09-15-2008, 08:14 AM   #4 (permalink)
Originally Posted by blitzer_26 View Post
i agree,
Thanks for the responses everyone - doesn't sound like compatiblity will be a problem. As for the electrical/interior things, I'd like to take the interior on the wrecked door and plop it onto the new door. I presume that everything should line up.....is this correct?
Also, are there any detailed descriptions anywhere on how to take out the interior portion?
Thanks again!
Old 09-15-2008, 08:34 AM   #5 (permalink)
Asteroid's Avatar
View Asteroid's Photo Gallery
It may not be so simple. Is there any damage to the B pillar or is it just superficial damage to the door skins?
04 ACV36R Camry Sportivo 4cyl manual
92 CE100 Corolla DX diesel (jdm import) *sold*
Asteroid is offline   Reply With Quote
Old 09-15-2008, 10:07 AM   #6 (permalink)
Asteroid, what are the problems I might encounter? The front door was bent a bit at the edge. The back door was just door skin damage.
Old 09-16-2008, 12:35 AM   #7 (permalink)
View djb2's Photo Gallery
The rear doors are trivial to swap. You can latch the door shut and then bolt on the hinge. The inner panels are also easier to swap, and you don't have to swap the lock cylinder.
If the front doors hinge is bent, you might be able to swap it by removing it from the door, and mounting just the replacement hinge without the door attached. When I did this, I though it would be easier to align with the door bolted to the hinge and took off the fender for access. That was a mistake, since I needed to remove dozens of fasteners -- far more than the few obvious ones I originally saw.
djb2 is offline   Reply With Quote
