94 Camry LE: Foam blowing out of vent - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2008, 02:22 PM   #1 (permalink)
View fidelio's Photo Gallery
The air vent on my 1994 Camry LE blows out little pieces of foam. These bits of foam break apart as soon as I touch them. There is also a strange smell from the vent. Do I need to change the cabin filter or something similar? I searched for help on this, but it seems that they didn't have cabin filters on models before 2001(?).
Thanks in advance.
fidelio is offline   Reply With Quote
Old 09-15-2008, 06:03 PM   #2 (permalink)
Gameroom cash: $303255
This is pretty common. Toyota uses this foam to seal where pieces of the duct system connect to each other. As it get old it dries up and get's brittle and some of it blows out in to the passenger compartment. It is more common on the generation 4's rather than your generation 3, but it can happen to any year. Nothing really to worry about. Your duct system is probably operating at 98% efficiency now.
As to your other question, you are correct in that your car does not have a cabin air filter. You car probably has some mold built up in the a/c system. This is also pretty common in many car makes, not just Toyota. You can try spraying some Lysol in to the vents just in front of the windshield, while moving the selector lever in the car to the various vent positions, including inside and outside air. If this doesn't help, most auto parts stores sell a kit with some chemical to get rid of the moldy smell. Personally, I think Lysol works just as well.
Mike
Old 09-15-2008, 09:02 PM   #3 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
What I do is set the system to fresh air and roll down all the windows. Then I have someone spray Lysol in the fresh air vent under the passenger side windshield wiper while I sit in the car with the blower on high, changing the vent selections.
I usually do this when I clean the car (once every month or 2).
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 09-16-2008, 02:02 PM   #4 (permalink)
Kisuke in rain
Mazeraski's Avatar
View Mazeraski's Photo Gallery
Hmm...I'll have to try the Lysol idea. Mine smells a little funny sometimes.
1992 Toyota Camry LE 5SFE 4 cyl. 2.2L
A.K.A. "Ron Burgundy"
198,000 mi. (as of February 9th, 2010) and counting
Mazeraski is offline   Reply With Quote
Old 09-16-2008, 07:28 PM   #5 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
I've had foam get blown out on the gen 3.5. Hasn't happened in a while, but as Mike pointed out, it's just insulation from the insides.
What I do is press the A/C button to turn the A/C off but have the fan run, a few minutes before I reach home or wherever I'm going. That way there isn't much moisture left in the vents when I park my car and go about my day.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 09-16-2008, 09:16 PM   #6 (permalink)
"What I do is press the A/C button to turn the A/C off but have the fan run, a few minutes before I reach home or wherever I'm going. That way there isn't much moisture left in the vents when I park my car and go about my day."
Some cars now have a system to keep the fan running for a few minutes after the engine has been shut off, to accomplish the same thing. I think it's GM models, but I'm not certain. This really sounds like a good idea, especially in warm climates where the A/C is used constantly.
Mike
Old 09-16-2008, 09:25 PM   #7 (permalink)
Mike
I think that's a good idea to automatically run the fan for a bit afterwards to dry the ducts and vents out. The last GM car I've driven was an '08 Malibu Classic and it didn't have that feature. Maybe it's on the redesigned Malibu and its variants.
My aunt has an '04 Accord and her A/C has a weird smell for the first 5-10 seconds. She's started to run the fan before she gets to work/home but it hasn't gone away. I'll check it out for her the next time I see her. I have to change her windshield wipers and cabin air filter.
moving forward
