94 Camry Horrible Hesitation Gas Smell *Video*
Hello,
I have a 94 2.2L. Recently it began acting as if it were about to run out of gas so I would put more in knowing it had at least 4 gallons still left. This seemed to fix the problem, but more than likely something else. The other day I was going to accelerate from a stop and it wouldn't budge. It took about 10-15 seconds to get the tach to 3000 where it would seem to drive a lot smoother.
Idle is horrible and it putts along sounding as if it is missing on a couple cylinders. I checked the oil and it looks fine, but has a possible gas smell. This may be in my head, but waiting on a friend to come and verify. I am going tomorrow to check what I can and if I cannot find an answer, it may be dealership time ($$!). THere is also a burning smell that is not oil. It burns some oil, but this is more like a clutch or brake pad kind of smell.
Has anyone had anything similar to this or things I can check? I am planning on checking the plugs which I am sure are fouled out, timing, and compression. It has a new fuel pump for about 1000 miles and new distributor, plugs/wires, PCV for about 4000 miles. Any help is definitely appreciated. Also prior to this it always ran hesitant until 3000RPM, but was driveable. While like this I still got good gas milage. Thanks
