The alt output runs directly to the battery. Output at 1500-2000 should be 13.5 to 15.1v at the battery.
Turn on ign key and determine if the Alt light comes on and then goes off after starting engine.
Find the B output terminal at back case of the Alt, should be a larger separate wire bolted to the Alt. Check voltage output at this wire engine at 1500-2000, should be as stated above. Terminal B runs to the battery.
If less then this above voltage find Terminal F on the back of the Alt case. This is a separate terminal labeled "F". Ground terminal F and start engine, then check output voltage. If output is more then above voltage the regulator has a problem, if less the Alt has a problem. Make sure you have the right terminal!
The regulator is built into the back of the Alt.
After the engine has been off for 20 minutes apply a load to the battery. For 20 seconds turn on the headlights, heater blower, rear defogger, etc. and ign switch. After 20 seconds turn all items off.
Measure voltage at the battery (ign all all other items now off). Should be 12.55-12.9 volts if much less the battery has a problem.
