I doubt it's a problem with the timing belt jumping a few teeth. While that would shift the ignition timing because the distributor is driven via one of the cams, resetting the ignition timing wouldn't completely get it running right, because the valve timing would still be off.
Ignition advance is done electronically; no vacuum advance.
When you checked the timing, did you put a jumper across terminals E1 & TE1 of the diagnostics plug? You won't get an accurate reading if you didn't.
So either the distributor is moving on you, or it's defective, or the ECU that controls timing advance is going haywire. A possible problem with the distributor, although it's just a guess; In the picture in my Haynes manual, it appears the distributor shaft coupler that engages with the camshaft is held on with a pin. Perhaps that has sheared and it's allowing the shaft to rotate and get out of time? You'd have to remove the distributor to check that out.
