Leaking near AIC - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2008, 10:16 PM   #1 (permalink)
View 94_v6_camry's Photo Gallery
Leaking near AIC
Below is a pic of my car leaking...
http://img220.imageshack.us/my.php?i...2008365un1.jpg
What is the likely cause of it???
What is the best method to clean it ???
Derrick
94_v6_camry is offline   Reply With Quote
Old 09-22-2008, 10:39 PM   #2 (permalink)
just a nobody
Brake cleaner can probably clean it up nicely. Check your PCV valve, that is the crankcase vent hose. The hose may also be a little old and hardened too, may have to replace it.
N.E.O.
Old 09-22-2008, 10:50 PM   #3 (permalink)
N.E.O.
Kool where exactly is the PVC valve on the Gen3 V6 engine ???
Derrick
Old 09-22-2008, 11:12 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
on the rear valve cover under the intake plenum
it's always a good idea to check and replace your pcv since it releases pressure as needed...often you can get more blow-by from the crankcase vent or leak from your rear main seal, etc because your pcv isn't working properly
HaHa
Old 09-22-2008, 11:13 PM   #5 (permalink)
just a nobody
At the front corner of the rear valve cover, I believe. Can't be 100% for sure, since I haven't seen one of them for a while. Anyway, it is somewhere on the back valve cover.
N.E.O.
Old 09-23-2008, 12:11 AM   #6 (permalink)
Any pic guys ???
How much does it cost???
Derrick
Old 09-23-2008, 01:12 AM   #7 (permalink)
just a nobody
Sorry no pict! It is probably around $20 including the grommet, which usually falls apart on an older engine. Don't know about down under though.
This link is for a later model 3.0, but should be fairly similar to yours: new PCV valve (PICS)
N.E.O.
Old 09-23-2008, 01:19 AM   #8 (permalink)
What is the main reason to replace the part?? bad idle ???
Does it improve mileage (spelling) ???
Derrick
Old 09-23-2008, 01:39 AM   #9 (permalink)
just a nobody
No so much to do with improve mileage, well, maybe just a little. When the PCV system is operating, it lower the crankcase pressure, so oil won't get push out through the seals and gaskets when the engine is turning high rpm. A stuck or plugged PCV valve could cause excess oil consumption, oil leaks, etc
Most of the time it is replaced for maintenance purposes.
N.E.O.
