Solenoid- replace? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2008, 05:21 PM   #1 (permalink)
View RadioFlyer90's Photo Gallery
Solenoid- replace?
My wife's '98 Camry 4-cyl. has developed a starting problem. Sometimes, when we turn the key, we get a good, solid click, but no crank. Sometimes it does this once, sometimes lots of times. When it does crank, it cranks over well and starts right up. I cleaned the battery terminals, and nothing changed. I suspect the solenoid is bad, but the solenoid is very expensive. The only other thing I can imagine is that the starter is bad, but it is expensive as well. Has anyone else had this problem? Should I suck it up and replace the whole unit? Is there a quick fix for the existing parts?
1990 Toyota Pickup, 2wd, 4-spd, reg. cab (sold!)
1998 Toyota Camry, 4cyl auto
1971 Toyota Hilux, 4cyl, 4spd, 4wd, 4 tires...
RadioFlyer90 is offline   Reply With Quote
Old 09-23-2008, 07:01 PM   #2 (permalink)
just a nobody
Replace the starter contacts.
N.E.O.
Old 09-23-2008, 10:47 PM   #3 (permalink)
Gameroom cash: $303255
I agree. Sounds like the common worn starter solenoid contacts problem. Do a search on this forum for "Starter Contacts". The subject and it's repair options have been covered many times on this forum.
Mike
