Really dumb question... - Toyota Nation Forum : Toyota Car and Truck Forums
Closed Thread
Old 09-23-2008, 08:38 PM   #1 (permalink)
Restoring a '92 Camry
cmitchell5254's Avatar
View cmitchell5254's Photo Gallery
3rd Generation Really dumb question...
Is there any kind of lubricant or sealant or anything that I should apply to new spark plugs before installation?
cmitchell5254 is offline
Old 09-23-2008, 08:41 PM   #2 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
nope, just make sure you follow the torque specs either in your service/repair manual or on the box
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Venom_5 is offline
Old 09-23-2008, 09:36 PM   #3 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
+1 on the torque specs, but there are lubricants for spark plugs. While they are not specific to spark plugs, they are sold in small packets containing just enough for use on spark plugs. You can use anti-seize compound on the threads so the plugs are easier to remove when you change them. Then use dilectric grease where the plug wire boot attaches to the plug so the rubber boot dosesn't stick to the plug. The grease also helps keep out moisture.
Both the anti-seize, and grease can be found at the parts counter in any auto parts store. They usually sell for $0.99 each packet.
I've been using anti-seize, and dilectric grease on my spark plugs for 10 years, and I've never had a problem.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline
Old 09-23-2008, 11:02 PM   #4 (permalink)
View importcar's Photo Gallery
How much anti seize do you apply?
importcar is offline
Old 09-23-2008, 11:21 PM   #5 (permalink)
uibalnme's Avatar
Just a thin coat. Enough to cover all the threads.
uibalnme is offline
Old 09-23-2008, 11:40 PM   #6 (permalink)
Venom_5's Avatar
those packets are only sold to make people like you waste money ... i see its working
people have NOT being using these packets for more than 10 years with no problems as well
Venom_5 is offline
Old 09-24-2008, 12:37 AM   #7 (permalink)
uibalnme's Avatar
Well, whatever you say "O Great, and all Knowing Venom"...
Don't insult my intelligence by implying I'm a rube that falls for simple tricks that take my money. I've had a problem with stuck plugs, and torn plug boots getting stuck in the plug tubes before. I learned of the stuff from a family friend, who has been a professional mechanic for nearly 40 years. So, I speak from personal experience. It's just cheap insurance against possible future headaches. The anti-seize aids instalation, AND removal of the plugs. The dilectric grease not only helps keep moisture out, it also helps the plugs slip out of the spark plug socket after being properly torqued.
Besides what's $2 and change every 12-15,000 miles when the plugs are due for inspection or replacement? I'm not soooo broke that I can't spare 2 bucks on the anti-seize and dilectric grease every time I check the plugs.
Hell, I still have some of each packet left over from the last time I checked the plugs in Jan. Each packet has enough to do a set of 8 plugs. Since I have a 4cyl., well do the math. $2 for both packets once a year. How much does the average person spend at starbucks a week?
Anyway, they don't have to use anti-seize or dilectric grease if they don't want to. Your statment saying that there isn't anything that can be used was incorrect. I'm just presenting the fact that there are things that can be used on the plugs.
Withholding facts, and information is inconducive to the education of the uninitiated.
uibalnme is offline
Old 09-24-2008, 07:13 AM   #8 (permalink)
View proftomda's Photo Gallery
ASE mechanic and FAA licensed aircraft mechanic here. As mentioned, they do make "anti sieze compound" for the threads and dielectric grease for the plug wire boots. Contrary to Venom's remarks, use of these products is the right way to service the plugs and reccomended. You can buy these products at any parts store and sold in small packets or larger sizes. A little goes a long way.
proftomda is offline
Old 09-24-2008, 09:34 AM   #9 (permalink)
groovemasterodi's Avatar
View groovemasterodi's Photo Gallery
glad to see Atlanta represented here
2001 Camry..5FSE..
groovemasterodi is offline
Old 09-24-2008, 10:35 AM   #10 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426253
View EEngineer's Photo Gallery
venom got pwned
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline
Old 09-24-2008, 10:41 AM   #11 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
i agree, anti-seize is very handy and works very well. recommended but not needed
TheKevin is offline
Old 09-24-2008, 11:02 AM   #12 (permalink)
2000camryle's Avatar
View 2000camryle's Photo Gallery
put on the anti seize or you will be wishin you did in the future, when we were taking off a part when replacing a seal anti seize was not applied the last time it had been put on and my dad had to go rent a pully that could mechanically take it off because it was not coming off any other way, it prevents rust from forming and just a little bit of dust makes it very difficult to get parts off. btw it was not cheap to rent that pully so why not just spend the extra dollar and then take liek a minute or less to apply it. that is the only experience I have had with it so I may not be entirely correct but that is what I have had to deal with.
2000camryle is offline
Old 09-24-2008, 02:47 PM   #13 (permalink)
3rd Generation
No doubt, sir.
Old 09-24-2008, 07:23 PM   #14 (permalink)
Did you ever make it down Griffin/McDonough way to check out Summits?
2001 Camry..5FSE..
Old 09-24-2008, 07:37 PM   #15 (permalink)
rty
Gameroom cash: $298766
View rty's Photo Gallery
I don't use grease nor do I torque to specifications. Maybe if you didn't torque it so much you wouldn't need grease?
rty is offline
Closed Thread
